[OpenLayers-Users] WFS Popup Attributes undefined
Cress B.
cress.bates at co.lane.or.us
Tue Oct 6 16:58:01 EDT 2009
I'm fairly new to OpenLayers and have been trying to get the attributes from
my WFS mapfile to display in a popup window. I would like the user to be
able to click on a polygon and have the attributes display as a list in a
popup. I've started with the select-feature-openpoup.html example and have
inserted by own WFS mapfile. I can load my polygon shapefile as a WFS
service and see them load as orange polygons - although they load REAL slow.
When I activate the popup option and click on a polygon the popup window
comes up and the polygon is highlighted in blue. The popup is returning the
area of the polygon as part of the 'feature.geometry.getArea()' parameter;
but the other attributes in my shapefile are "undefined" in the popup. I've
hacked away for several days, reading almost all the posts dealing with
popup, WFS, attributes... and still can't figure out what I'm doing wrong.
So I'm not sure if my WFS mapfile is wonky or if my script in OpenLayers is
missing something.
Below is my Mapfile:
MAP
NAME 'TAXLOT'
STATUS ON
IMAGETYPE PNG24
TRANSPARENT ON
EXTENT 4239905 896089 4247235 902911
SIZE 1000 800
IMAGECOLOR 152 252 210
UNITS Feet
SHAPEPATH "/ms4w/apps/tutorial/data"
FONTSET "/ms4w/apps/tutorial/fonts/fonts.list"
SYMBOLSET "/ms4w/apps/tutorial/symbols/symbols35.sym"
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wfs_title" "TAXLOT"
"wfs_onlineresource" "http://localhost/cgi_bin/mapserv.exe?&"
#map=homeinfo_wfs.map&"
"wms_srs" "EPSG:32127"
END #end metadata
END #end web
PROJECTION
"init=epsg:32127"
END #end projection
LAYER # Taxlots polygon layer begins here
NAME "taxlots"
CONNECTIONTYPE WFS
METADATA
"wfs_typename" "taxlots"
"wfs_request_method" "GET"
"gml_featureid" "FID"
"gml_include_items" "all"
"queryable" "true"
END
DATA 'HomeTaxlots'
TYPE POLYGON
STATUS ON
PROJECTION
"init=epsg:32127"
END
DUMP TRUE
TEMPLATE /ms4w/apps/template/foo.html
CLASS
NAME "lots"
STYLE
COLOR 155 155 255
OUTLINECOLOR 0 15 27
END
TEMPLATE "ttt_query.html"
END
END # Taxlots polygon layer ends here
END # All map files must come to an end just as all other things must come
to...
And this is the OpenLayers script piece for the popup:
<script type="text/javascript">
var map, drawControls, selectControl, selectedFeature;
var lon = 4243545;
var lat = 900150;
var zoom = 0;
var map, test_wfs, layer;
function onPopupClose(evt) {
selectControl.unselect(selectedFeature);
function onFeatureSelect(feature) {
selectedFeature = feature;
var maplot = selectedFeature.attributes['MAPLOT'];
var lot = selectedFeature.attributes['LOT'];
var acres = selectedFeature.attributes['ACRES'];
var taxcode = selectedFeature.attributes['TAXCODE'];
popup = new OpenLayers.Popup.FramedCloud("info",
feature.geometry.getBounds().getCenterLonLat(),
null,
"<div style='font-size:.8em'>TaxLot: "
+ maplot +"<br />Lot: " + lot+"<br />Acres: " +acres +"<br/>Taxcode: "
+taxcode+"<br/>Area: " + feature.geometry.getArea()+"</div>",
null, true,onPopupClose);
feature.popup = popup;
map.addPopup(popup);
function onFeatureUnselect(feature) {
map.removePopup(feature.popup);
feature.popup.destroy();
feature.popup = null;
function init(){
var options = {
projection: new OpenLayers.Projection("EPSG:32127"),
displayProjection: new OpenLayers.Projection("epsg:32127"),
units: "feet",
maxResolution: "auto",
allOverlays: true,
maxExtent: new OpenLayers.Bounds(4239905, 895089,
4247235, 906500)
map = new OpenLayers.Map("map",options
var polygonLayer = new OpenLayers.Layer.WFS( "TAXLOT",
"http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/homeinfo_wfs_good.map&",
{typename: 'taxlots'});
//var polygonLayer = new OpenLayers.Layer.Vector("Polygon
Layer");
map.addLayers([polygonLayer]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.MousePosition());
selectControl = new
OpenLayers.Control.SelectFeature(polygonLayer,
{onSelect: onFeatureSelect, onUnselect: onFeatureUnselect});
drawControls = {
polygon: new OpenLayers.Control.DrawFeature(polygonLayer,
OpenLayers.Handler.Polygon),
select: selectControl
for(var key in drawControls) {
map.addControl(drawControls[key]);
map.setCenter(new OpenLayers.LonLat(0, 0), 3);
function toggleControl(element) {
for(key in drawControls) {
var control = drawControls[key];
if(element.value == key && element.checked) {
control.activate();
} else {
control.deactivate();
View this message in context: http://n2.nabble.com/WFS-Popup-Attributes-undefined-tp3778098p3778098.html
