[OpenLayers-Users] WMS SRS:EPSG4326 with OpenLayers doesn´t work
Andreas Hocevar
ahocevar at opengeo.org
Wed Oct 7 03:58:01 EDT 2009
Bytechanger wrote:
> I want add a baselayer from WMS in EPSG 4326
> but this doesn´t work!
> 1.
> map=new OpenLayers.Map('map', { projection: new
> OpenLayers.Projection("EPSG:4326"), ...);
Ok, although EPSG:4326 is the default so you do not need to set it.
> 2. var TestLayer= new OpenLayers.Layer.WMS("Test", "http://www.geo
> ....?", { REQUEST: 'getMap', SRS:'EPSG:4326' ...},{isBaseLayer:true});
Don't add REQUEST and SRS params -- OpenLayers will do that for you. But
make sure to add a LAYERS param.
> map.addLayer(TestLayer);
> But I don´t see anything !! No mapdata....
You have to zoom to an extent first to see something:
map.zoomToMaxExtent();
Also look at one of the examples (e.g.
http://openlayers.org/dev/examples/lite.html) to see how this works.
> when I want to get the WMS-Request...
> TestLayer.getURL(map.Extent());
Extent() is not a method of the map, so what you are trying to do here
cannot work.
> I get wrong EPSG !!!! the Request inherits: &SRS=EPSG%3A4326 <- RIGHT!
> &BBOX=-76506.698386357, and so on <- WRONG Coordinate Format!!!!!!
> map.Extent() returns also the wrong format !!!!!!!!
map.Extent() will raise an exception. Did you mean map.getExtent()?
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
