[OpenLayers-Users] Using an SLD from Geoserver in my WMS
request and the opacity isn't working for the fill
Pere Roca Ristol
peroc79 at gmail.com
Thu Oct 8 01:36:14 EDT 2009
have you tested with "normal" PNG?
I have seen in
http://www.sitepoint.com/blogs/2007/09/18/png8-the-clear-winner/ that with
png8 pixels are either solid or completely transparent, but never partially
see-through.
Geoserver 1.6.2 had a bug with png8 and empty images (not your case)
transparency.
Pere
jim.meyer wrote:
> Hi everyone,
> My WMS layers is defined as follows (NOTE: shapeStyle corresponds to
> the
> SLD below):
> var shapelayer = new OpenLayers.Layer.WMS(
> "Shapes",
> "/geoserver/wms?",
> layers: 'SUA:schedule',
> styles: shapeStyle,
> srs: 'EPSG:4326',
> format: 'image/png8',
> cql_Filter: cqlfilter,
> tiled: 'true',
> transparent: true
> 'isBaseLayer': false, 'wrapDateLine': true
> The geoserver SLD is defined as follows:
> <?xml version="1.0" encoding="UTF-8"?>
> <StyledLayerDescriptor version="1.0.0" xmlns="http://www.opengis.net/sld"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
> <NamedLayer>
> <Name>green</Name>
> <UserStyle>
> <Name>green</Name>
> <Title>Green polygon</Title>
> <Abstract>Green fill with black outline</Abstract>
> <FeatureTypeStyle>
> <Rule>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter name="fill">#732615</CssParameter>
> <CssParameter name="fill-opacity">0.3</CssParameter>
> </Fill>
> <Stroke>
> <CssParameter name="stroke">#732615</CssParameter>
> <CssParameter name="stroke-opacity">0.8</CssParameter>
> <CssParameter name="stroke-width">1</CssParameter>
> </Stroke>
> </PolygonSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> When the shape is rendered on the screen, the fill opacity is ignored.
> Is there a way to correct this?
> Thanks,
> Jim
> Jim Meyer
> Java Programmer
> ConceptSolutions, LLC
> We Make Business Intelligent
> 703.889.8434 [desk]
> 703.391.9041[fax]
> www.Concept-Solutions.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Using-an-SLD-from-Geoserver-in-my-WMS-request-and-the-opacity-isn-t-working-for-the-fill-tp3783294p3786076.html
