[OpenLayers-Users] Recommendation for large number of points?
Andreas Hocevar
ahocevar at opengeo.org
Thu Oct 8 05:39:04 EDT 2009
18,000 POIs are impossible to handle on the client. Consider using a WMS
(like GeoServer or Mapserver) to render your POIs, and use
OpenLayers.Control.WMSGetFeatureInfo or OpenLayers.Control.GetFeature to
make the POIs interactive.
Regards,
Andreas.
MattL wrote:
> I'm working with a large site that contains somewhere in the area of 18,000
> points of interest. I have tried two setup scenarios - the first using a WFS
> Layer and Vectors, and the second using a GML Layer (text input) with
> Markers.
> Both setups resulted in giving browsers (most noticeably IE6) a huge
> workout, causing full CPU load and wait times to process the points. I have
> lessened the rendering load by restricting the maxResolution to more
> manageable zoom levels, but this can be hit or miss where some areas have
> more clusters of data points.
> What options do I have for managing this set of data? What are normal
> recommendations when it comes to plotting large sets of data with OL?
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
