[OpenLayers-Users] How to use split events
Andreas Hocevar
ahocevar at opengeo.org
Thu Oct 8 06:14:17 EDT 2009
instead of working with the split event, use a beforesplit event handler
and check the geometry of the target feature. Return false from the
beforesplit handler if the target feature has more than 1 part (note:
before splitting!).
Regards,
Andreas.
emmexx wrote:
> I'm trying to use the split control to cut a line (LineString) with the
> conditione that the line can only be cut in 2 parts.
> I tried to use the split event with the following code:
> split: function(event) {
> var a = event.original;
> var b = event.features;
> if (b.length>2)
> //do something to stop splitting
> but I couldn't find a way to accomplish it. I tried all of the following
> to no avail:
> event.features=null
> this.deactivate()
> event.features=event.original
> Is there a simple way to do it or should I use a 2 steps strategy,
> setting a flag in the split event and restoring the original feature in
> the aftersplit event?
> Thank you
> maxx
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
