[OpenLayers-Users] OpenLayers.Layer.Text - Place marker on
click without file
Alex G.
unseen.wizard at gmail.com
Thu Oct 8 09:55:24 EDT 2009
The problem with Layer.Text is that it accepts a tab delimited file while I
wanted to pass coords, a title and a description for a marker.
I was able to do do that with adding a few parameters to location and with
some editing of the Text.js file.
Here are the new variables:
layerToUse:null,
newLon:null,
newLat:null,
newTitle:null,
newDesc:null,
newIcon:null,
layerToUse places the marker on an existing layer instead of creating a new
one (functionality I was looking for).
And also changed the following code:
loadText: function() {
if (!this.loaded) {
if (this.location != null) {
var onFail = function(e) {
this.events.triggerEvent("loadend");
this.events.triggerEvent("loadstart");
OpenLayers.Request.GET({
url: this.location,
success: this.parseData,
failure: onFail,
scope: this
this.loaded = true;
else if (this.newTitle != null && this.newDesc != null) {
this.parseData();
parseData: function(ajaxRequest) {
if (ajaxRequest != null) {
var text = ajaxRequest.responseText;
} else {
if(this.newIcon == null) this.newIcon = "";
var text = "point\ttitle\tdescription\ticon\n" + this.newLat +
"," + this.newLon + "\t" + this.newTitle + "\t" + this.newDesc + "\t" +
this.newIcon + "\n";
var options = {};
as well as
data['overflow'] = feature.attributes.overflow || "auto";
var markerFeature = new OpenLayers.Feature(this.layerToUse,
location, data);
this.features.push(markerFeature);
var marker = markerFeature.createMarker();
if ((feature.attributes.title != null)
&& (feature.attributes.description != null)) {
marker.events.register('click', markerFeature,
this.markerClick);
if (this.layerToUse != null) {
this.layerToUse.addMarker(marker);
} else {
this.addMarker(marker);
Also from my HTML file I call:
var new4 = new OpenLayers.Layer.Text( "Texts", { layerToUse: markers,
newLat: '4420851.767102', newLon: '698762.34033203', newTitle: "Test Title
2", newDesc: "This is a description 2"} );
new4.parseData();
Instead of:
map.addLayer(new4);
In summary, what this does is, it feeds specific layer, coords, title and
description to the function.
I also discovered a nice little bug. If you hide an overlay while a marker
bubble is open, the marker disappears while the bubble still stays there.
This also happens on the OL examples (markersTextLayer.html).
I hope I didn't go the long way around to solving this problem...
On Thu, Oct 8, 2009 at 3:29 PM, Christopher Schmidt <crschmidt at metacarta.com
> wrote:
> On Thu, Oct 08, 2009 at 01:27:30PM +0300, Alex G. wrote:
> > Hi all,
> > I am interesting in constructing a function that places a marker with a
> > bubble text as provided by OpenLayers.Layer.Text but I want to provide
> > coordinates, title and description on the fly (without saving them to a
> file
> > and then loading them to the function).
> > I am using the OpenLayers example to catch clicks and then place a simple
> > marker using markers.addMarker(new OpenLayers.Marker(new
> > OpenLayers.LonLat(lonlat.lon,lonlat.lat),icon)); and everything seems to
> > working fine.
> > But I cannot seem to be able to figure out a way to do the same for
> > OpenLayers.Layer.Text.
> Er... It shouldn't be any different? Can you share your current code
> that isn't working?
> -- CHris
> > I am guessing some heavy modification of Layer/Text.js is required? Is
> there
> > maybe a patch around that could help me on this since my Javascript
> > knowledge is pretty bad.
> > Thanks in advance!
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091008/8c96d9ac/attachment.html
