[OpenLayers-Users] how to add kml file and analyse with openlayers?
zhoujian_ab
zhoujian_ab at 163.com
Thu Oct 8 21:14:51 EDT 2009
Hi:
I also write the kml examples like sundial on openlayers web. I can,t achieve the same result to use geoserver's 'topp: states'. The following is the code, I don,t know what,s wrong. Thanks.
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<link rel="stylesheet" href="source/style1.css" type="text/css" />
<link rel="stylesheet" href="source/style.css" type="text/css" />
<style type="text/css">
#map {
width: 100%;
height: 80%;
border: 1px solid black;
.olPopup p { margin:0px; font-size: .9em;}
.olPopup h2 { font-size:1.2em; }
</style>
<script src="OpenLayers/OpenLayers.js"></script>
<script type="text/javascript">
var lon = -100;
var lat = 60;
var zoom = 5;
var map, select;
function init(){
map = new OpenLayers.Map('map');
var wms = new OpenLayers.Layer.WMS(
"OpenLayers WMS",
"http://localhost:8081/geoserver/wms",
{layers: 'topp:states'}
var sundials = new OpenLayers.Layer.Vector("KML",{
projection: map.displayProjection,
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: "states.kml",
format: new OpenLayers.Format.KML({
extractStyles: true,
extractAttributes: true
map.addLayers([wms, sundials]);
select = new OpenLayers.Control.SelectFeature(sundials);
sundials.events.on({
"featureselected": onFeatureSelect,
"featureunselected": onFeatureUnselect
map.addControl(select);
select.activate();
map.zoomToExtent(new OpenLayers.Bounds(-127.61950064999999, 23.7351786,-64.08177035, 50.5925234000000056));
function onPopupClose(evt) {
select.unselectAll();
function onFeatureSelect(event) {
var feature = event.feature;
// Since KML is user-generated, do naive protection against
// Javascript.
var content = "<h2>"+feature.attributes.name + "</h2>" + feature.attributes.description;
if (content.search("<script") != -1) {
content = "Content contained Javascript! Escaped content below.<br/>" + content.replace(/</g, "<");
popup = new OpenLayers.Popup.FramedCloud("chicken",
feature.geometry.getBounds().getCenterLonLat(),
new OpenLayers.Size(100,100),
content,
null, true, onPopupClose);
feature.popup = popup;
map.addPopup(popup);
function onFeatureUnselect(event) {
if(feature.popup) {
map.removePopup(feature.popup);
feature.popup.destroy();
delete feature.popup;
</script>
</head>
<body onload="init()">
<h1 id="title">KML Layer Example</h1>
<div id="tags"></div>
<p id="shortdesc">
Demonstrates loading and displaying a KML file on top of a basemap.
</p>
<div id="map" class="smallmap"></div>
<div id="docs"></div>
</body>
</html>
I am making a digital map with Openlayers+geoserver+postgis. But It is my first time to use openlayers, I need some guides. I am Chinese, and my MSN is zhoujianab at hotmail.com. Thanks for your viewing, I need your help. If you can, please give me a way to contact, just like MSN, ICQ or QQ and so on. thank you. I am looking forward your reply.
2009-10-09
zhoujian_ab
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091009/3903419b/attachment.html
