[OpenLayers-Users] How to achieve getfeatureinfo-popup in
my local computer.
Ingo Weinzierl
ingo.weinzierl at intevation.de
Fri Oct 9 05:13:34 EDT 2009
Hi zhoujian_ab
your OpenLayers application is running and all layers are displayed fine?
What's the output after clicking on an object?
Regards,
Ingo
* zhoujian_ab <zhoujian_ab at 163.com> [20091009 03:08]:
> Hi:
> I am following the example of getfeatureinfo-popup to write down the code. And I want to use geoservers example to get the feature in my local computer like the example when click the object I can see its feature in a popup window. However, I can't. I don't know why. Please help me . Thanks a lot.
> <html>
> <head>
> <title>GetFeatureInfo Popup</title>
> <script src="openlayers/OpenLayers.js"></script>
> <link rel="stylesheet" href="source/style1.css" type="text/css" />
> <link rel="stylesheet" href="source/style.css" type="text/css" />
> <script>
> OpenLayers.ProxyHost = "proxy.cgi?url=";
> var map, info;
> function load() {
> map = new OpenLayers.Map({
> div: "map",
> maxExtent: new OpenLayers.Bounds(143.834,-43.648,148.479,-39.573)
> var political = new OpenLayers.Layer.WMS("State Boundaries",
> "http://localhost:8081/geoserver/wms",
> {'layers': 'topp:tasmania_state_boundaries', transparent: true, format: 'image/gif'},
> {isBaseLayer: true}
> var water = new OpenLayers.Layer.WMS("Bodies of Water",
> {'layers': 'topp:tasmania_water_bodies', transparent: true, format: 'image/gif'},
> {isBaseLayer: false}
> //what's mean of the red code?(I capy form the example)
> var highlight = new OpenLayers.Layer.Vector("Highlighted Features", {
> displayInLayerSwitcher: false,
> isBaseLayer: false
> map.addLayers([political,water, highlight]);
> info = new OpenLayers.Control.WMSGetFeatureInfo({
> url: 'http://localhost:8081/geoserver/wms',
> queryVisible: true,
> eventListeners: {
> getfeatureinfo: function(event) {
> map.addPopup(new OpenLayers.Popup.FramedCloud(
> "chicken",
> map.getLonLatFromPixel(event.xy),
> null,
> event.text,
> null,
> true
> map.addControl(info);
> info.activate();
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.zoomToMaxExtent();
> </script>
> </head>
> <body onload="load()">
> <h1 id="title">Feature Info in Popup</h1>
> <div id="tags"></div>
> <p id="shortdesc">
> Demonstrates the WMSGetFeatureInfo control for fetching information
> about a position from WMS (via GetFeatureInfo request). Results
> are displayed in a popup.
> </p>
> <div id="map" class="smallmap"></div>
> <div id="docs"></div>
> </body>
> </html>
> 2009-10-09
> zhoujian_ab
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ingo Weinzierl <ingo.weinzierl at intevation.de> | Tel.: +49 (0)541-33 508 3773
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
