[OpenLayers-Users] GetFeature: select best feature using centroid
Duncan Sayers
duncansayers at threefivesouth.net
Fri Oct 9 06:33:21 EDT 2009
Here's the scenario:
I am mapping a number of sites where I want to be able to click on or
near a site (sites displayed via mapserver wms - data in Postgis), and
do a WFS GetFeature to bring up a polygon associated with that site
and draw it in a Vector layer.
I've simplified this for testing using simple 5km buffers for each
site in a separate Layer (also postgis -> mapserver wms/wfs etc). Many
of these polygons overlap so it's not a simple matter of grabbing the
polygon that contains the click position. The buffers will obviously
have their centroid at the site, and the final shapes will be line-of-
sight plots, where the centroid will be closeish. But it seems that
the selectBestFeature function in GetFeature.js grabs the polygon
whose edge is nearest the click position via the distanceTo function -
not the behaviour I'm after but I can't seem to find anything to
change it.
So I've modified the GetFeature control slightly replacing the line in
the selectBestFeature function:
dist = point.distanceTo(feature.geometry, {edge: false});
With...
var centroid = feature.geometry.getCentroid();
dist = point.distanceTo(centroid, {edge: false});
It works brilliantly, but I was wondering if anyone knows of a
function/option that I haven't found that enables me to achieve the
same without needing my dodgy hack, or alternatively suggest a
completely different approach?
Thanks,
Duncan Sayers
