[OpenLayers-Users] Display WMS Layer
Paul Curran
paulcurran9 at googlemail.com
Fri Oct 9 11:15:07 EDT 2009
Hi, I posted about this problem a little while ago and i still cant get past
it.
My WMS layer will only display if STATUS is set to DEFAULT within the
mapfile. If status is set to ON, i get following error message within OL Map
window. "WMSLoadGetMapParams(): WMS Server Error". What am i missing to call
the layer within openlayers?
My Code is as follows:
var bounds = new OpenLayers.Bounds(0, 0, 660046, 1229782);
var map, layer1, layer2;
var options = { maxExtent: bounds, maxResolution: 1000, numZoomLevels:
10};
function init(){
map = new OpenLayers.Map('map', options);
layer1 = new OpenLayers.Layer.WMS("OpenLayers WMS",
http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/apps/openlayers-2.8/data/uk2.map",
{ layers: "250" },
{gutter: 15});
map.addLayer(layer1);
map.zoomToMaxExtent();
Thanks for any help in advance
Paul
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091009/118d0ed3/attachment.html
