Daniel Morissette wrote: > > First add this to your Apache config: > > # Force MapServer to accept mapfiles refs only using env vars > SetEnv MS_MAP_NOPATH "yes" Small typo: The name of the variable should be MS_MAP_NO_PATH -- Daniel Morissette http://www.mapgears.com/
