[OpenLayers-Users] Featureserver + Openlayers
goliah
bianchimro at gmail.com
Tue Oct 13 16:49:37 EDT 2009
Thanks Alexandre,
I'll check it out.
Do you think I should switch to a mapfish server for a production app?
It seems like it is more mantained.
Thanks again
Mauro
Alexandre Dube wrote:
> Hi,
> Here's a working OpenLayers+FeatureServer demo :
> http://dev4.mapgears.com/bdga-fs/
> It uses the MapFish protocol since MapFish server can be "talked to"
> pretty much the same way as FeatureServer.
> Hope this helps,
> Alexandre
> goliah wrote:
>> Dear list,
>> I'm trying to use OpenLayers and Feature Server.
>> What i'd like to do is use WFS-T protocol to make a simple feature
>> editor.
>> I've set up Featureserver (beautiful software) easily under CGI, and
>> tried
>> to setup something like the
>> WFS-Transactional example:
>> http://www.openlayers.org/dev/examples/wfs-protocol-transactions.html
>> I've had some problems using this example on my server, in particular
>> with
>> WFS protocol, that I had to change to HTTP Protocol for making things
>> work
>> I ended up with this code:
>> http://www.maurob.org/fttest/index.html
>> on line 113 you can find the wfs layer declaration:
>> //code here
>> wfs = new OpenLayers.Layer.Vector("Scribble", {
>> protocol: new OpenLayers.Protocol.HTTP({
>> url:
>> "http://www.maurob.org/featureserver/featureserver.cgi/scribble",
>> format: new OpenLayers.Format.GeoJSON()
>> strategies: [
>> new OpenLayers.Strategy.Fixed(),
>> saveStrategy
>> projection:new OpenLayers.Projection("EPSG:4326")
>> //end code
>> This because, if using OpenLayers.Protocol.WFS I couldn't set the right
>> format to talk to featureserver.
>> It is quite working now (can add and modify features),
>> Anyway, I still cannot delete feature (seems like DELETE request is not
>> understood by Featureserver)
>> Do you think mine is a reasonable setup of the wfs layer declaration in
>> openlayers (protocol/format) ?
>> which is right way to handle it?
>> Thanks a lot for any idea.
>> Mauro
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Featureserver-Openlayers-tp3797197p3818851.html
