[OpenLayers-Users] Control access to WMS
Robert Sanson
SansonR at asurequality.com
Wed Oct 14 15:34:34 EDT 2009
I have made copies of mapserv.exe in my cgi-bin to other names such as
gsswms.exe. I then have a line at the bottom of httpd.conf:
SetEnvIf Request_URI "/cgi-bin/gsswms.exe?"
MS_MAPFILE=/ms4w/apps/service/nztm.map
So I then use a layer definition for OL such as :
var topowms = new OpenLayers.Layer.WMS( "Topos",
"http://10.64.20.120/cgi-bin/gsswms.exe?",
{layers:
['nzislands','nznoaa','nz1mtm','nz250ktm','ci250k','nz50ktm','ci50kcitm'],
transparent: 'true',format: "image/png"},
{singleTile: true, isBaseLayer: false,
minResolution: 2000, visibility: false} );
regards,
Robert Sanson
>>> <Steve.Toutant at inspq.qc.ca> 15/10/2009 2:53 a.m. >>>
Thanks all for your help,
I'll have in a near future to implement a fully secured private site
since I'm gonna have to publish VERY sensible data via WMS. I can tell
that this issue scares the IT group. Story to follow...
But for now, obscurity is sufficient.
I'm a bit in obscurity myself regardin http_referer...I need to know
more about the mechanic...
It's not clear what I should do in the mapfile and in my OpenLayers
code?
I added Daniel's code in Apache conf.
"Then your WMS requests should refer to the mapfile using "map=MYMAP"
instead of a full path. If the referrer is not valid, then MYMAP will
not be set and MapServer will spit out an error."
Do I need to use the MYMAP environment variabble in the mapfile or in
OL code, or both?
I'm using OpenLayers to create a WMS layer with new
OpenLayers.Layer.WMS(name, url, params, options);
Instead of the path of the mapfile should I use MYMAP (Environment
variable MYMAP defined in the conf of Apache). If so, Is there some
magic there to get the environment variable value? Should I get it with
some php code?
Thanks
Steve
Daniel Morissette <dmorissette at mapgears.com>@openlayers.org
Envoyé par : users-bounces at openlayers.org
13/10/2009 02:56 PM
A
users at openlayers.org cc
Objet
Re: [OpenLayers-Users] Control access to WMS
Christopher Schmidt wrote:
> If you care about people 'stumbling in', this would be sufficient. If
you
> actually want to ensure people can't use the data outside of your
app,
> it's not.
> Yeah, something like that is what I would probably do if I wanted
something
> taht was obscurity and not security. :)
I agree (and I never used the word security). But this may be
sufficient
in some simple cases. :)
And for a more complete Access Control solution, everyone is invited to
a presentation of the new GeoPrisma project in a conference near you:
FOSS4G 2009 (Sydney, 2009-10-23):
http://2009.foss4g.org/presentations/#presentation_146
Géomatique 2009 (Montréal, 2009-10-21):
http://www.geomatique2009.com/en/papers/program
Daniel
Daniel Morissette
http://www.mapgears.com/
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
Click here (
https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==
) to report this email as spam.
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091015/f3f16c66/attachment.html
