[OpenLayers-Users] the problem of geowebcache
Andreas Hocevar
ahocevar at opengeo.org
Fri Oct 16 02:17:40 EDT 2009
instead of creating the OverviewMap with your layer, create it with
layer.clone().
Regards,
Andreas.
zhoujian_ab wrote:
> Hi list,
> Are there someone to use geowebcache? I found a problem of
> geowebcache. Now I am using geoserver+openlayers+postgresql to making
> map, when I start to use geowebcache, the overview of map can not work
> as usual, it looked as lost the centre. However, when I shut up the
> geowebcache, the overview can work normally. I don't know why? Do you
> come across the same question?
> Regards.
> 2009-10-15
> zhoujian_ab
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
