[OpenLayers-Users] Strange behaviour with panel and custom
control
David Alda Fernandez de Lezea
dalda at ikt.es
Fri Oct 16 02:37:13 EDT 2009
Hello, thanks for your answer, if you see the code I provided I think I'm specifying those handlers you talk about in the constructor:
> * Constructor: OpenLayers.Control.Switch
> * Fires a user defined function when toggled on/off
> * Parameters:
> * options - {func} An optional object whose properties will be used
> * to extend the control.
> initialize: function(on, off, options) {
> OpenLayers.Control.prototype.initialize.apply(this, [options]);
> this.userOn = on;
> this.userOff = off;
And then when I call the constructor:
> var oDrawSelCtrl = new OpenLayers.Control.IktSelectTool(f1,f2,{
> id:"oSelFeatureCtrl", title: 'Selección', displayClass:
> 'olSelectFeature'});
"...and you should call activate/deactivate method of OpenLayers.Control when you overrite the activate/deactivate method."
Do you mean doing something like this??
* Method: activate
* Override OpenLayers.Control.activate to call user defined "on" function
activate: function () {
this.activate()
this.userOn();
return true;
* Method: deactivate
* Override OpenLayers.Control.deactivate to call user defined "off" function
deactivate: function () {
this.deactivate();
this.userOff();
return true;
"And you can using the SelectFeature control instead of yourself."
I tried to do that, but I don't know why it didn't work for me. My goal is to select features from a WFS Layer, and this's the unique way that I found that worked for me. Maybe is too complicated or not much sofisticated but it works, and it works pretty well.
Thanks
You should specify the handlers in the constructor of your control, and you should call activate/deactivate method of OpenLayers.Control when you overrite the activate/deactivate method.
David Alda Fernandez de Lezea wrote:
> Hello list,
> Sorry but I don't know how the previous message was sent incomplete
> and by mistake. I'll go on:
> I managed to develope a custom control called IktSelectTool.js which
> basically selects and highlights fetures from a WFS layer . The
> control doesn't select features, but it registers a click event on the
> map to select the WFS features (that's my idea). The registry of the
> event and the selection of the features works fine, and know I want to make a tool.
> Basically the source of this file is:
> /* Copyright (c) 2006-2007 MetaCarta, Inc., published under the Clear
> BSD
> * license. See
> http://svn.openlayers.org/trunk/openlayers/license.txt
> for the
> * full text of the license. */
> * @requires OpenLayers/Control.js
> * Class: OpenLayers.Control.IktSelectTool
> * Inherits from:
> * - <OpenLayers.Control>
> OpenLayers.Control.IktSelectTool = OpenLayers.Class(OpenLayers.Control, {
> * Property: type
> * {OpenLayers.Control.TYPE}
> type: OpenLayers.Control.TYPE_TOOL,
> * Parameters:
> this.userOn = on;
> this.userOff = off;
> * Method: activate
> function
> if (this.active) {
> return false;
> if (this.handler) {
> this.handler.activate();
> this.active = true;
> this.userOn();
> return true;
> function
> if (this.active) {
> if (this.handler) {
> this.handler.deactivate();
> this.active = false;
> this.userOff();
> return true;
> return false;
> * Method: userOn
> * placeholder for the user defined function that will be fired
> when Switch is activated
> userOn: function(){
> * Method: userOn
> when Switch is deactivated
> userOff: function(){
> CLASS_NAME: "OpenLayers.Control.IktSelectTool"
> I create the control in my init function in this way:
> where f1 is the function which is triggered when the control is
> activated and f2 is the function which is triggered when the function
> is deactivated. For my test they are only two functions that do
> nothing (just create somo strings to see if they work), but the idea
> is to register or unregister a map event. Then I add this control to my panel by this way:
> panel.addControls([oDragPanCtrl,history.next,
> history.previous,zoombox,oZoomBoxOutCtrl,
> zoomtomaxextent,oDrawLnCtrl,oDrawPtCtrl,oDrawPolCtrl,oDrawSelCtrl]);
> And in my index.html I've defined the corresponding CSS class:
> /* SelectFeature */
> .olControlPanel .olSelectFeatureItemActive{
> background-image: url("images/Select_on.png");
> background-repeat: no-repeat;
> background-position: 0px 0px;
> .olControlPanel .olSelectFeatureItemInactive{
> background-image: url("images/Select_off.png");
> At this point everything is OK, the page can be loaded without errors
> and all that stuff. The strange behaviour I'm talking about is that
> when I select the tool, the tool's image is not uploaded, I mean, it
> doesn't change from Select_off.png to Select_on.png, but if I drag a
> bit on the map or make a zoom, the tool's image is uploaded. I'd like
> to figure out what's happening because the user, future user of the
> app, won't know that the tool is activated until he makes a zoom or
> something related to the map.
> Can someone, please, help me with this problem.
> Thanks again.
> Un saludo,
> David Alda Fernández de Lezea
> Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y
> Biodiversidad
> IKT
> Granja Modelo s/n · 01192 · Arkaute (Araba)
> Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
> email: dalda at ikt.es web: www.ikt.es
> <http://www.ikt.es/>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Strange-behaviour-with-panel-and-custom-control-tp3828331p3833135.html
Users mailing list
