[OpenLayers-Users] loading panel update
bartvde at osgis.nl
bartvde at osgis.nl
Sun Oct 18 13:49:36 EDT 2009
Recently a few issues have been reported with the loading panel addin,
e.g. not being able to use the mousewheel zoom when the loading panel is
visible, and not being able to click a marker. This was all caused by the
loading panel div having the same size as the map. I've modified the
loading panel code [1] so that the div size is only the size of the
animated gif (update to the css class), which should minimize problems.
Ofcourse there will still be issues when somebody is exactly on top of the
animated gif, but chances are much less that this will lead to problems.
Please try out the code (svn update from
http://svn.openlayers.org/addins/loadingPanel/trunk/) and report any
issues. TIA.
Best regards,
Bart
[1] http://trac.openlayers.org/changeset/9744
