[OpenLayers-Users] Updating Text Layer - flickering markers
Andreas Hocevar
ahocevar at opengeo.org
Sun Oct 18 19:25:49 EDT 2009
Ran Manor wrote:
> Hi,
> I implemented your suggestion using a GML layer but I couldn't figure
> out how to tell the layer to reload the source text file.
> How do I do that?
Don't use Layer.GML, but Layer.Vector. Configure it with a HTTP protocol
with Text format and a Fixed Strategy. To reload, do strategy.load().
Regards,
Andreas.
> Thanks.
> - Ran
> On Thu, Oct 8, 2009 at 12:05, Andreas Hocevar <ahocevar at opengeo.org
> <mailto:ahocevar at opengeo.org>> wrote:
> rmanor wrote:
> > I have a map with a single text layer.
> > My text file is being updated every minute so I wrote a code that
> destroys
> > the existing layer and creates a new one.
> > The markers are updated correctly but when they do, I get this
> annoying
> > "flickering" effect of the markers' icons. It's not so bad when
> the markers
> > are moving but if the markers are at the same place, they just
> flicker on
> > the spot.
> > Anyway to make this look nicer?
> Don't destroy the layer before creating a new one. Create a new layer,
> and destroy the old one when the new one is loaded (i.e. in a loadend
> event handler of the new layer).
> An even smarter way would be to not use a Markers layer, but a Vector
> layer with HTTP protocol, Text format and a Fixed strategy. Then you can
> just load the new text file, and there will be no flicker.
> Regards,
> Andreas.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
Andreas Hocevar
