[OpenLayers-Users] Optimal tile size for tilecache
Adrian Popa
adrian_gh.popa at romtelecom.ro
Wed Oct 21 01:06:27 EDT 2009
Thank you for your explanations.
Regards,
Adrian
Christopher Schmidt wrote:
> On Tue, Oct 20, 2009 at 04:25:01PM +0300, Adrian Popa wrote:
>> Thank you,
>> I'll try with mod_python.
>> Another small question - is there any notable speed difference between
>> using tilecache (let's say through mod_python) to serve some pre-cached
>> tiles and using OpenLayers.Layer.Tilecache to serve the same pre-cached
>> tiles?
> Some. The key difference is that serving pre-cache tiles can be done on much
> lower resource webservers. mod_python can get bulky, but Layer.TC can
> read from a minimal webserver like lighthttpd, etc. that tileCache itself
> wouldn't want to be run on.
>> I'm thinking if I should pre-cache my whole map and use Layer.Tilecache
>> or if I can get away by using tilecache.py...
> You probably don't need to pre-cache your whole map. You will see a
> tremendous speedup switching to mod_python.
>> Has anyone done any benchmarks for these methods? If the speed
>> difference isn't that great, I wouldn't sacrifice the disk space...
> The speed difference is not quite nonexistent, but is negligable for
> anything but the most demanding use case (hundreds of users, etc.)
>> Thank you.
>>> On Tue, Oct 20, 2009 at 09:43:35AM +0300, Adrian Popa wrote:
>>>> Hello Christopher,
>>>> Thanks for your reply.
>>>> I am using cgi mode (because it's been the easiest to setup). How do
>>>> you recommend I run tilecache? I don't want to precache my whole map
>>>> because most of the zoom levels (in some areas) don't give much
>>>> information. I could precache some zoom levels and let the details be
>>>> rendered on the fly, when needed...
>>> Okay, using CGI is the problem. You can only get about 10 tiles/second
>>> with CGI, compared to hundreds with WSGI, mod_python, etc. So I recommend
>>> setting up mod_python or some other persistant server side process for
>>> serving the tiles, rathere than using CGI, which is much slower.
>>>> I'm not using metatiles (or at least I think I'm not using them)... I
>>>> don't really know what metatiles are and what they are supposed to
>>>> do. Maybe a point to the right documentation would be ok...
>>>> The tile loading process goes like this - when I change my zoom the
>>>> center tiles are loaded pretty quickly (even if they haven't been
>>>> cached) - in about half a second, but the edges of my image take
>>>> about ~5 seconds to load. I thought it might be a limitation of my
>>>> browser - on how many connections it can keep - so I added a lot of
>>>> connections (20 per server) both on my browser and my web server
>>>> (20 processes listening). The speed limitation is visible even when
>>>> the tiles (for that area) have been cached. I thought that by
>>>> increasing the tile size the browser would make fewer requests and
>>>> the page would maybe load faster...
>>>> Thanks,
>>>> Adrian
>>>>> On Mon, Oct 19, 2009 at 02:30:44PM +0300, Adrian Popa wrote:
>>>>>> Hello everyone,
>>>>>> Just wondering - what would be a good tile size to be used for
>>>>>> tilecache, so that the client will not do a lot of queries to the
>>>>>> server (seems they take quite a while), and at the same time
>>>>>> would not load too much information that is not used (areas of
>>>>>> tiles which are outside the viewable area).
>>>>>> My web clients use screen resolutions starting from 1200x1024
>>>>>> (and usually run the page in full screen).
>>>>>> Right now I have tiles of 256x256 - which seem rather small and
>>>>>> take some time to load.
>>>>> I would try to understand why they take some time to load. Are you using
>>>>> CGI mode? (Don't.) Are you not-precaching as much as you should? Are you
>>>>> using metatiles? Are you not using metatiles? etc.
>>>>> Also, some description of 'some time' -- hundreds of milliseconds, seconds,
>>>>> dozens of seconds -- would probably also be appropriate.
>>>>>> What tile sizes do you use?
>>>>> 256x256. And so does Google Maps, which was doing this before most of us,
>>>>> and probably has a decent idea on how to make things work pretty well.
>>>>> -- Chris
>>>>>> Thanks,
>>>>>> Adrian
>>>>>> _______________________________________________
>>>>>> Users mailing list
>>>>>> Users at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091021/1189041a/attachment.html
