[OpenLayers-Users] MultiPolygons
Scott Lewis scott.lewis at nsidc.org
Tue Oct 27 10:50:29 EDT 2009
Polygon objects have an exterior ring and (optionally) multiple interior
rings.  With OpenLayers, when you create a Polygon object, the first
Ring you provide is the exterior ring; the rest are the interior rings.
  If you had multiple "holes", you could add them.
Seems like you found out how to get it to do what you want, but I
figured it wouldn't hurt to know "why" it works!
A MultiPolygon would be used if you have multiple, independent polygons
that you wanted grouped together; each polygon could have internal rings
also, but each polygon would be a separate entity and wouldn't really
affect the definition of the other polygons.  You are correct that for
what you need, a MultiPolygon isn't needed.
Scott
Brad Spencer wrote:
> Ok, found out that if you just force two LinearRing geometries into the
> same polygon object you get two polygons that are fused together as it
> were. No need to use MultiPolygon!
> var parcel01= new OpenLayers.Geometry.LinearRing(pointList01);
> var parcel02 = new OpenLayers.Geometry.LinearRing(pointList02);
> var polygonFeature = new OpenLayers.Feature.Vector( new
> OpenLayers.Geometry.Polygon([parcel01, parcel02]));
> At least it does what I want.
> Cheers,
> Brad…
> *From:* users-bounces at openlayers.org
> [mailto:users-bounces at openlayers.org] *On Behalf Of *Brad Spencer
> *Sent:* Tuesday, October 27, 2009 5:52 PM
> *To:* openlayers users
> *Subject:* [OpenLayers-Users] MultiPolygons
> List,
> I cannot see any examples of this so thought someone may have done the
> and can help me.
> Its not clear how to make a multiPolygon vector object. I can create
> individual polygons no problem but how for example would you generate
> two concentric circles  as a single polygon with no lines joining the
> two circles? This would be is the same as a donut shape.
> Cheers,
> *Brad Spencer*
> NuMaps
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
