[OpenLayers-Users] Display WMS layer depending on ZoomLevel
Arnd Wippermann
arnd.wippermann at web.de
Tue Oct 27 14:00:15 EDT 2009
you have added minZoomLevel and maxZoomLevel to the params or your WMS
layer. params are used for building the WMS request. Move them to the
options of your WMS layer and perhaps it works. I use minScale and maxScale
to control the display of layers.
{ gutter:15,
minZoomLevel : 5,
maxZoomLevel : 10
//minScale : 1000000,
//maxScale : 45000
Arnd
_____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Paul Curran
Gesendet: Dienstag, 27. Oktober 2009 16:08
An: users at openlayers.org
Betreff: [OpenLayers-Users] Display WMS layer depending on ZoomLevel
Hello i need your help.
I currently have two layers. i would like to display one layer initially
then zoom in closer and display the second layer. I have been trying to do
it like this:
var options = { maxExtent: bounds, maxResolution: 600, numZoomLevels: 10};
layer1 = new OpenLayers.Layer.WMS("OpenLayers WMS",
"http://127.0.0.1/cgi-bin/mapserv.exe?", { layers: "uk", map:
'/ms4w/apps/openlayers-2.5/data/uk2.map',
minZoomLevel: 1, maxZoomLevel: 4 },
{ gutter: 15 });
layer2 = new OpenLayers.Layer.WMS("OpenLayers WMS",
"http://127.0.0.1/cgi-bin/mapserv.exe?", { layers: "UK250", map:
minZoomLevel: 5, maxZoomLevel: 10},
{ gutter: 15 });
map.addLayer(Layer1, Layer2);
map.zoomToExtent(bounds);
map.setCenter(bounds);
map.zoomToMaxExtent();
My main problem is i can only display a layer when status is DEFAULT within
mapfile however i cannot hide the layer if set to this. When Set to ON the
layer is not displayed atall.
Any help much appreciated
Cheers
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091027/d63287fa/attachment.html
