[OpenLayers-Users] Fw: problem with Internet Explorer and multiple
layer
fsalas
fsalas at geocuba.cu
Thu Oct 29 11:51:54 EDT 2009
Thanks , Till and Andreas
The problem is over , thanks for your contribution.
Regards,
Salas
----- Original Message -----
To: "Andreas Hocevar" <ahocevar at opengeo.org>
Sent: Tuesday, October 27, 2009 1:07 PM
Subject: Re: [OpenLayers-Users] problem with Internet Explorer and multiple
layer
> From: "Andreas Hocevar" <ahocevar at opengeo.org>
> To: "fsalas" <fsalas at geocuba.cu>
> Cc: <users at openlayers.org>
> Sent: Tuesday, October 27, 2009 7:35 AM
> multiple
> layer
>> Hi,
>> this happens because IE6 does not support alpha transparency on 24bit PNG
>> images. Try adding
>> format: "image/gif",
>> transparent: true
>> to your layer params when using IE6. This will give you an 8-bit image
>> with transparency.
>> Regards,
>> Andreas.
>> fsalas wrote:
>>> Hi,
>>> I have one Open Layer projects with multiple layers , in Mozila Firefox
>>> work very well , but when try to use IE only show one layer, because the
>>> last layer hide the others.
>>> How I can resolve this problems?
>>> Regards , salas
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
