[OpenLayers-Users] Overlays only at specific zoom levels
Eric Lemoine eric.lemoine at camptocamp.com
Thu Oct 29 13:14:35 EDT 2009
On Wednesday, October 21, 2009, Derek Watling <derek at cmainfo.co.za> wrote:
> I am using Google base layers in OpenLayers 2.8 with a my own WMS overlay
> that is only avalilable at at the top 3 zoom levels. My bounding box is set
> to cover South Africa. I have the Google zoom levels limited to between 5
> and 18 with the following code:
>     var bbox = new OpenLayers.Bounds(bbox = 1780677, -4180188, 3683653,
> -2512026);
>     var mapOptions = {
>         projection: new OpenLayers.Projection("EPSG:900913"),
>         units: 'm',
>         maxResolution: 156543.0339,
>         maxExtent: bbox,
>         restrictedExtent: bbox
>     var map = new OpenLayers.Map('divMap', mapOptions);
>     map.addControl(new OpenLayers.Control.LayerSwitcher());
>     var gmap = new OpenLayers.Layer.Google("Google Streets", {
> "sphericalMercator": true });
>     gmap.MIN_ZOOM_LEVEL = 5;
>     gmap.MAX_ZOOM_LEVEL = 18;
>     var myOverlay = new OpenLayers.Layer.WMS(
>         "Custom Overlay",
>         "http://dev/Tilecache/tilecache.py?",
>         { layers: "Custom", 'maxExtent': bbox, format: "image/png" }
>     myOverlay.setIsBaseLayer(false);
>     myOverlay.displayOutsideMaxExtent = 0;
>     myOverlay.transitionEffect = "resize";
>     map.addLayers([gmap, myOverlay]);
> How do I tell OpenLayers that myOverlay only exists for the following
> resolutions?
> 2.38865713348388, 1.19432856674194, 0.597164283370971
have you tried passing these resolutions to youe WMS layer, through
the "resolutions" config option. It should make OpenLayers "stop" the
layer when it's out of range.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
