[OpenLayers-Users] WMSGetFeatureInfo Format - get bounds
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Oct 29 13:20:12 EDT 2009
Eric,
are you referring to:
http://trac.openlayers.org/ticket/2255
I think that's a different issue since it deals with the new GML parser,
while the GetFeatureInfo format uses the old GML parser.
Best regards,
Bart
Eric Lemoine wrote:
> On Thursday, October 29, 2009, Alexandre Dube <adube at mapgears.com> wrote:
>> Hi Bart,
>> bartvde at osgis.nl wrote:
>>> Hi Alexandre,
>>> so you only have the boundedBy element and not the actual geometry in the
>>> output?
>> Yep, no geom is needed for my case.  The bbox is enough.
>>> If so, I don't think this is currently possible, can you please file an
>>> enhancement bug in Trac?
>> Done : http://trac.openlayers.org/ticket/2329
> Hi. I think there already is a ticket for this. IIRC we had some
> discussion about this a while ago, it was initiated by François
> Vanderbiest. I'm interested in discussing this again. Sorry I can't
> look up the ticket and the discussion at the moment.
> Cheers,
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
