[OpenLayers-Users] Openlayers selection on Geowebcached layer?
Dragan Podvezanec
dragan.podvezanec at gmail.com
Fri Oct 30 15:49:10 EDT 2009
Is this possible at all?
Currently I use WMS layer from Geoserver, and I can make selection on it,
and get all needed feature info:
onclick.events.register("featureselected", this, function(e) {
var object = (e.feature);
var bbox = (object.geometry.bounds);
var center = (bbox.getCenterLonLat());
map.panTo(center);
This doesn't work when I try to make the same behaviour on the same layer
from Geowebcache.
Do I have to modify geowebcache.xml somehow to enable feature requests, or
this isn't possible at all?
View this message in context: http://n2.nabble.com/Openlayers-selection-on-Geowebcached-layer-tp3921094p3921094.html
