[OpenLayers-Users] Create feature from sketch by imitating a
bouble-click event
Andreas Hocevar
ahocevar at opengeo.org
Tue Sep 1 17:58:24 EDT 2009
Andreas Hocevar wrote:
> Hi Amit,
> why don't you just use a DrawFeature control with a Path handler on a
> vector layer and listen to the layer's sketchmodified event, checking
> for feature.geometry.components.length?
> var layer = new OpenLayers.Layer.Vector("result");
> var control = new OpenLayers.Control.DrawFeature(layer,
> OpenLayers.Handler.Path);
> layer.events.on({
> sketchmodified: function(evt) {
> if(evt.feature.geometry.component.length == 2) {
The above line should read
if(evt.feature.geometry.components.length == 2) {
Regards,
Andreas.
> control.handler.finalize();
> You will then have the feature on your layer. Nothing else to do.
> Regards,
> Andreas.
> Amit Andersen wrote:
>> Hi All
>> I wonder if there is a good reason why my post is being ignored.
>> Is it to hard or is the problem posted not clear enough?
>> Mails with different problems have been streaming to my mailbox, and got an
>> answer quite fast. Kan someone write back if my post is not answerable in
>> some way.. :-)
>> Thanks
>> Amit
>>> Hi
>>> This should be a simple question.
>>> I'm working on limiting a path to one single line. What I did was to fire
>>> a function on "Point" event. A global var is counting the points created.
>>> In this function when the global var is 2, I have an alert which pops up
>>> fine.
>>> What I want to do instead of the alert, is create the feature from the
>>> line sketch on second single-click. Basically imitate a double-click event
>>> on the second single-click.
>>> This is my DrawFeature control:
>>> line: new OpenLayers.Control.DrawFeature(vectors, OpenLayers.Handler.Path,
>>> {callbacks: { "point": this.TwoClickPath.bind(this) }}),
>>> And this is the function that is being fired:
>>> TwoClickPath: function(e) {
>>> this.TwoClickPathCount++;
>>> if (this.TwoClickPathCount == 2) {
>>> Here I want to create the a feature out of the sketch (which
>>> is a single line)
>>> // alert(""); fires ok
>>> controls.line.deactivate();
>>> this.TwoClickPathCount = 0;
>>> Thanks in advance for any reply.
>>> Amit
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
