[OpenLayers-Users] WFS layer prechargement with layer not
visible possible?
Andreas Hocevar
ahocevar at opengeo.org
Wed Sep 2 05:08:30 EDT 2009
Jimmy Aumard wrote:
> Hi Eric,
> How I know if the layer is loaded or not?
Register a listener for the layer's loadend event...
> And the user have possibility to save the point on layer (but not the
> same every time he have choice on hislayer).
... and add your Save control in that event. Then, register a listener
for e.g. each of your editable layer's visibilitychanged event (or an
application event if you use a different mechanism to change the
editable layer) and disable/enable the Save control for that layer.
Regards,
Andreas.
> For the "Terms Of Service" I don't know but it's just a prototype for
> the moment, if it's not possible with Google I take another geocoder
> for the finale version.
> Thanks
> Jim
> 2009/8/27 Eric Lemoine <eric.lemoine at camptocamp.com
> <mailto:eric.lemoine at camptocamp.com>>
> On Wednesday, August 26, 2009, Jimmy Aumard
> <jimmy.aumard at gmail.com <mailto:jimmy.aumard at gmail.com>> wrote:
> > Thanks Kris,
> > My problem is :
> > Users have possibility to search an address (geocoding google)
> and save this address(feature) on a vector layer (but maybe the
> layer is not charged). If layer was charged I have no problem but
> if layer was not charged the feature is not added on layer when
> layer was charged (feature erase).
> Why don't you enable the geocoding function only once the layer is
> loaded?
> PS: does the Google "Terms Of Service" allow you to use their geocoder
> and display the results on something else that Google maps?
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
