[OpenLayers-Users] Ta not working on IE7
Andreas Hocevar
ahocevar at opengeo.org
Wed Sep 2 17:37:36 EDT 2009
"bt" is not a valid value for labelAlign. Also, make sure that you are
really working with OpenLayers 2.8 and not a release candidate, because
there was an issue with IE7 (http://trac.openlayers.org/ticket/2135).
Regards,
Andreas.
newbie wrote:
> Dear All,
> Recently I just switch from openlayer2.7 to 2.8. Then I use this
> coding to get a tag beside my vehicle icon. The problem here is that it
> works fine in firefox and IE6. But in IE7 the tag is not appearing. Any
> solution for IE7? pointFeature.style = { externalGraphic: imageName,
> graphicWidth:34,
> graphicHeight:17,
> pointRadius: 10,
> rotation: vehicleDetail3[1],
> label : "test",
> fontColor: "black",
> fontSize: "20px",
> fontFamily: "Arial",
> fontWeight: "bold",
> labelAlign: "bt"
> Thank you in advance.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
