[OpenLayers-Users] Layer from GML loading only for the first
time
bartvde at osgis.nl
bartvde at osgis.nl
Mon Sep 7 06:25:55 EDT 2009
you are probably running into browser cache. So either change the cache
settings on your webserver for the XML1 subdir (tell the browser to never
cache the file), or append a random number to the url.
Best regards,
Bart
> Dear Friends,
> I am having a query builder which allows an user to select one feature at
> a
> time.
> The geometry for this feature is then populated into a GML file format
> using
> another xml.
> So every time an user selects one feature the GML file is deleted and a
> new
> one created with the geometry of the new feature.
> Although GML file is created with every change in selection Openlayers is
> unable to load the changed GML and show it on the map.
> So openlayers is able to display the data from the GML for the first time
> only. So from second and subsequent selection it shows only the first
> feature on the map.
> The code is:
> map.addLayer(new OpenLayers.Layer.GML('choice_features',
> "XML1/FeatureGML.xml"));
> Is it a bug?
> If not how to tackle the problem.
> Thanks in advance.
> http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp3596382p3596382.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
