[OpenLayers-Users] Layer visibility problem
Brad Spencer brad at cubewerx.com.au
Wed Sep 9 05:52:45 EDT 2009
I load my layers when they required by the user. I first check to see if the
layer is already loaded and if not I load it but if its already been loaded
I just manage its visibility. That way you never have to load all the layers
up front. Just a thought.
Brad...
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of sunny74
Sent: Wednesday, September 09, 2009 7:15 PM
To: users at openlayers.org
Subject: [OpenLayers-Users] Layer visibility problem
Dear Friends,
I am now loading the layers in groups instead of individually.
First I am loading the base layer followed by 4 groups of layers, first
group contains 2 while others contain 3 each.
But the problem now is that at PageLoad for the first time the layers of
group1 are not visible because it is getting overlapped by the other layers.
The other layers are also not visible bec' they are mandated to be visible
at higher zoomin levels because of max/min scaledom.
Now if I load the group1 layers last then not only is it visible at initial
zoom level but also at higher zoom levels bec' in that case it is
overlapping the other layers mandated to be visible at that level.
So how to tackle the problem.
Can it be solved by changing the z-index of the first group at initial
PageLoad.
Pls provide some solution to this problem.
Thanks & Regards.
View this message in context:
http://n2.nabble.com/Layer-visibility-problem-tp3609424p3609424.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
