[OpenLayers-Users] Layer from GML loading only for the first
time
sunny74
sb.ray at hotmail.com
Thu Sep 10 01:22:06 EDT 2009
Thanks to all of you who replied.
Special Thanks to Leich Tobias and Armd Wippermann because your code solved
the problem.
Thanks a MILLION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Arnd Wippermann wrote:
> Hi,
> It seems you have to add a random number to the url.
> You take as url the same as you take for your gml layer.
> yourLayer.setUrl("XML1/FeatureGML.xml?A="+counter++);
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von sunny74
> Gesendet: Montag, 7. September 2009 20:32
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Layer from GML loading only for the first
> time
> Hi,
> Thanks for your reply.
> I am afraid I have not understood the solution suggested by you.
> You are saying to use the setURL to change the url for a gml layer after
> layer creation.
> Does that mean the following code:
> map.addLayer(new OpenLayers.Layer.GML('choice_features',
> "XML1/FeatureGML.xml"))
> after the creation of the above layer I use the setURL as below:
> choice_features.setUrl("http://....");
> Do i give just the Url for the GML file or do i need to add some random
> number to it at the end.
> Then how do I load the above Url.
> Regards.
>> Hi,
>> So far I rembember, there is a function setUrl to change the url for a
>> gml layer after layer creation. And also you link to the same as
>> previous, the new data will displayed.
>> So you don't need to add-remove-add your layer to display new data
>> from a GML vectorlayer.
>> yourLayer.setUrl("http://...."); should do the trick.
>> Arnd
>> [mailto:users-bounces at openlayers.org] Im Auftrag von sunny74
>> Gesendet: Montag, 7. September 2009 13:29
>> first time
>> Hi,
>> So how to do the following:
>> 1) change the cache
>> settings on your webserver for the XML1 subdir (tell the browser to
>> never cache the file)?
>> 2) append a random number to the url?
>> Pls tell in details.
>> Regards.
>> Bart van den Eijnden (OSGIS)-2 wrote:
>>> Hi,
>>> you are probably running into browser cache. So either change the
>>> cache settings on your webserver for the XML1 subdir (tell the
>>> browser to never cache the file), or append a random number to the url.
>>> Best regards,
>>> Bart
>>>> Dear Friends,
>>>> I am having a query builder which allows an user to select one
>>>> feature at a time.
>>>> The geometry for this feature is then populated into a GML file
>>>> format using another xml.
>>>> So every time an user selects one feature the GML file is deleted
>>>> and a new one created with the geometry of the new feature.
>>>> Although GML file is created with every change in selection
>>>> Openlayers is unable to load the changed GML and show it on the map.
>>>> So openlayers is able to display the data from the GML for the first
>>>> time only. So from second and subsequent selection it shows only the
>>>> first feature on the map.
>>>> The code is:
>>>> "XML1/FeatureGML.xml"));
>>>> Is it a bug?
>>>> If not how to tackle the problem.
>>>> Thanks in advance.
>>>> View this message in context:
>>>> http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-
>>>> t p3596382p3596382.html Sent from the OpenLayers Users mailing list
>>>> archive at Nabble.com.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp
>> 359638
>> 2p3596762.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users mailing list
> http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp359638
> 2p3598816.html
> Users mailing list
> Users mailing list
View this message in context: http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp3596382p3616280.html
