[OpenLayers-Users] attaching a control to an external div
Andreas Hocevar
ahocevar at opengeo.org
Thu Sep 10 13:18:36 EDT 2009
Hey-
P Kishor wrote:
> Per the docs for Control
> "Controls by default are added to the map they are contained within
> however it is possible to add a control to an external div by passing
> the div in the options parameter."
> which seems to be completely not like the source code at
> http://openlayers.org/dev/examples/mouse-position.html
> So, I have the following
> <div id="map"></div>
> <div id="coords"></div>
> <script type="text/javascript">
> // The following works, but the mouse position is displayed on the map
> var ctrl_coords = new OpenLayers.Control.MousePosition();
> map.addControl(ctrl_coords);
> // The following does not work
> var ctrl_coords = new OpenLayers.Control({div: "coords"});
> ctrl_coords.MousePosition();
This cannot work, it is syntactically incorrect.
> // The following also does not work
> var ctrl_coords = new OpenLayers.Control.MousePosition({div: "coords"});
Change the line above to:
var ctrl_coords = new OpenLayers.Control.MousePosition({div: document.getElementById("coords")});
> </script>
> Pointers please, as I want to display the mouse position inside the
> "coords" div. Does the documentation need to be updated as well?
The documentation looks accurate to me, since it says that the div
option expects a DOMElement, not a string. Just try the above fix and
you should be fine.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
