[OpenLayers-Users] How to change the style of the "cursor" when dragging/resizing/reshaping/rotating?
cgp carina_palanca at forcorp.com
Thu Sep 10 14:29:08 EDT 2009
I don't know what it's called, but you know when you click on a polygon (for
example) there is a point that appears in the middle of it for you to click
and drag? And then for resize/rotate, there is that same point that appears
on the polygon's bottom-right corner that you can use to drag around so you
can rotate or resize the polygon? How do you change that point's style so
that it's "standardized" for modifyFeature and easily distinguishable from
other points on the map? Perhaps, change it to a cross or 'x' style so that
we know that those are the points to be dragged instead of other markers on
the map?
Thanks for your help.
View this message in context: http://n2.nabble.com/How-to-change-the-style-of-the-cursor-when-dragging-resizing-reshaping-rotating-tp3618337p3618337.html
