[OpenLayers-Users] using openlayers as map interfacefordownloading pdf maps
maning sambale emmanuel.sambale at gmail.com
Fri Sep 11 03:12:26 EDT 2009
Arnd,
Thanks! This worked without a hitch!
On Thu, Sep 10, 2009 at 11:20 PM, Arnd Wippermann
<arnd.wippermann at web.de> wrote:
> Hi,
> Set extractStyles to false
> and add the following style to your layer after layer creation. It should
> also be possible to declare the style in the layer constructor.
> var styleMapLabel = new OpenLayers.StyleMap({'default':{
>    strokeColor: "#00FF00",
>    strokeOpacity: 1,
>    strokeWidth: 3,
>    fillColor: "#FF5500",
>    fillOpacity: 0.5,
>    pointRadius: 6,
>    pointerEvents: "visiblePainted",
>    label : "${description}",
>    //label : "name: ${name}, age: ${description}",
>    fontColor: "red",
>    fontSize: "12px",
>    fontFamily: "Arial",
>    fontWeight: "bold",
>    labelOffsetX: 10,
>    labelOffsetY: 10
>    //labelAlign: "${align}"
> map.layers[1].styleMap = styleMapLabel;
> map.layers[1].redraw();
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von maning sambale
> Gesendet: Donnerstag, 10. September 2009 09:13
> An: OpenLayers-Users
> Betreff: Re: [OpenLayers-Users] using openlayers as map
> Hi,
> In doing this webmap I have sample here:
> http://forest2002.essc.org.ph/test_map/
> What I want next is to:
> 1. show kml layer label in the map for each polygon (mapsheet name and
> number) 2. highlight color for the selected feature, either this one:
> http://openlayers.org/dev/examples/highlight-feature.html
> or this
> http://gis.ibbeck.de/ginfo/apps/planwerk/planwerk_nordbahntrasse.asp
> Any advise?
> On Thu, Sep 10, 2009 at 12:08 AM, Arnd Wippermann <arnd.wippermann at web.de>
> wrote:
>> Hi,
>> Have a look at
>> http://gis.ibbeck.de/ginfo/apps/planwerk/planwerk_nordbahntrasse.asp.
>> A click on a feature generates a link above the map for download of a pdf.
>> Arnd
>> [mailto:users-bounces at openlayers.org] Im Auftrag von maning sambale
>> Gesendet: Mittwoch, 9. September 2009 12:41
>> Betreff: [OpenLayers-Users] using openlayers as map interface
>> Hi,
>> We have prepared 1:250k sacle pdf topo maps for download.  I want to
>> use openlayers as an interface for downloading.  The plan is to show
>> the map boundingbox as a kml layer or georss over a slippymapy.  Each
>> box would provide a link to the pdf download.  Any sample I can work with.
>> Thanks in advance.
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> cheers,
> maning
> Users mailing list
cheers,
maning
