[OpenLayers-Users] Die Erlaubnis für den Aufruf der Methode XMLHttpRequest.open wurde verweigert - PGRouting
Mehmet Sirin m.sirin07 at googlemail.com
Fri Sep 11 20:31:50 EDT 2009
Okay, i destroyed the error "undefined function" by installing the package
php5-pgsql. Now everything works fine
thank you
kind regards
mehmet shirin
Am 12. September 2009 01:39 schrieb Mehmet Sirin <m.sirin07 at googlemail.com>:
> Hi, thanks, It really seems to solve that problem! But now I got another
> one:
> Firebug needs to POST to the server to get this information for url:
> http://localhost/OpenLayers/examples/routing2.php?startpoint=890544.23042729%206847095.3929257&finalpoint=893983.89669951%206848777.0075477&method=SPD&srid=900913
> This second POST can interfere with some sites. If you want to send the
> POST again, open a new tab in Firefox, use URL 'about:config', set boolean
> value 'extensions.firebug.allowDoublePost' to true
> This value is reset every time you restart Firefox This problem will
> disappear when https://bugzilla.mozilla.org/show_bug.cgi?id=430155 is
> shipped.
> When I push "Load Response": 890544.23042729<br>6847095.3929257<br><br />
> <b>Fatal error</b>: Call to undefined function pg_connect() in
> <b>/home/jars/workshop/OpenLayers/examples
> /routing2.php</b> on line <b>42</b><br />
> I think the last error is the main problem..
> Am 12. September 2009 00:12 schrieb Andreas Hocevar <ahocevar at opengeo.org>
>> Hi,
>> you have to run your application off a web server, not the file system.
>> Du mußt deine Anwendung auf einem Webserver installieren, statt sie vom
>> Dateisystem zu starten, d.h. du brauchst URLs, die mit http:// beginnen
>> statt mit file://
>> lg
>> Andreas.
>> Mehmet Sirin wrote:
>> > Hi, I got an error like "No access for for method XMLHttpRequest.open,
>> > when trying to calculate a route with pgrouting (data comes from
>> postgis).
>> > Hi, derzeit versuche ich mich am Tutorial
>> >  http://pgrouting.postlbs.org/wiki/WorkshopOL2.7andOSM bzw. habe schon
>> > alle dortigen Schritte ausgeführt. Nun, wenn ich Start und Endpunkte
>> > setze, dann auf "Calculate Route" drücke, bekomme ich einfach gar
>> > nichts angezeigt. Firebug sagt das hier:
>> > verweigert
>> > file:///home/jars/OpenLayers/lib/OpenLayers/Request/XMLHttpRequest.js
>> > Line 177
>> > verweigert
>> > open()()XMLHttpRequest.js (Linie 177)
>> > issue()(Object)Request.js (Linie 134)
>> > GET()(Object)Request.js (Linie 222)
>> > loadURL()("routing2.php?startpoint=889168.36391841
>> > 6851146.5554241&finalpoint=896888.50377383
>> > 6850611.4962262&method=SPD&srid=900913", null, null,
>> > displayRoute(response), null)Ajax.js (Linie 82)
>> > compute()index.html (Linie 199)
>> > onclick(click clientX=413, clientY=394)1YJQEPyB...BjA%3D%3D (Linie 2)
>> > [Break on this error] this._object.open(sMethod, sUrl, bAsync, sUser,
>> > sPassword);
>> > System: Ubuntu 8.04, Openlayers 2.8
>> > Hat jemand eine Idee zur Behebung dieses Problems? Ich bin dankbar für
>> > jede Hilfe.
>> > MfG
>> > Mehmet
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090912/954ef8a2/attachment.html
