[OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
Arnd Wippermann
arnd.wippermann at web.de
Thu Sep 17 18:20:57 EDT 2009
Hi salas,
It seems, your mapfile is not configured for EPSG:2085. There must be a line
in the WEB META Block like
'wms_srs' 'EPSG:2085 EPSG:4326 EPSG:900913 ' for the projection, you
wich to support.
Arnd
-----Ursprüngliche Nachricht-----
Von: fsalas [mailto:fsalas at geocuba.cu]
Gesendet: Donnerstag, 17. September 2009 23:31
An: Arnd Wippermann
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
Wichtigkeit: Hoch
Arnd,
Thanks for yours answer,
I was testing the example and I think that can be my solution but when i
translate to my code see below
function init(){
map = new OpenLayers.Map( 'map',{maxExtent:new
OpenLayers.Bounds(25.3600,32.8400,30.1800,35.5300),projection:
"EPSG:2085"});
// setup single tiled layer
mun = new OpenLayers.Layer.WMS( "Cuba",
"http://urano/cgi-bin/mapserv.exe?map=../htdocs/educacion/mapfile/educacion.
map",
{ "layers": "Municipios",
"format": "image/png",
"src": 'EPSG:2085',
"transparent": "TRUE"
mun.isBaseLayer=true;
map.addLayers([mun]);
// setup controls and initial zooms
map.addControl(new OpenLayers.Control.PanZoomBar());
map.addControl(new OpenLayers.Control.Navigation());
map.addControl(new OpenLayers.Control.Scale($('scale')));
map.addControl(new OpenLayers.Control.MousePosition({element:
$('location')}));
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.zoomToExtent(map.maxExtent);
******* This is the error inside openlayer maps in the page :********
msWMSLoadGetMapParams() : WMS server error
- Invalid src given : src must be valid or all requested layers
Regards , salas
----- Original Message -----
From: "Arnd Wippermann" <arnd.wippermann at web.de>
To: "'fsalas'" <fsalas at geocuba.cu>
Cc: <users at openlayers.org>
Sent: Wednesday, September 16, 2009 4:49 PM
Subject: AW: [OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
An example to show the use of SLD and SLD_BODY to change the style for WMS
layers:
http://gis.ibbeck.de/OLClient/examples/wms_world.asp
The WMS comes from MapServer.
Arnd
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von fsalas
Gesendet: Mittwoch, 16. September 2009 22:38
An: Ian Turton
Greetings Ian Turton.
I´m was checking all that you send me, but I am not sure that it is my real
problem.
That you help me with some example or other thing for to filter one layer
WMS with SLD or SLD_BODY?
To: "fsalas" <fsalas at geocuba.cu>
Cc: "Andreas Hocevar" <ahocevar at opengeo.org>; <users at openlayers.org>
Sent: Tuesday, September 15, 2009 9:43 AM
Subject: Re: [OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
> did you try not encoding the SLD in the function body? - it's possible
> that it is being encoded twice and thus makes no sense at the server
> end.
> Ian Turton
> Sent from State College, PA, United States
___________________________________
Dirección de Comunicaciones
Grupo Empresarial GEOCUBA
Este mensaje esta libre de virus.
Revisado por Kaspersky Antivirus
Definition count: 2582944
Definition date: 9/16/2009
SecurityPlus version: 3.0.5
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
Definition count: 2587297
Definition date: 9/17/2009
