[OpenLayers-Users] measure / measurepartial
Paul Spencer
pagameba at gmail.com
Fri Sep 18 09:47:13 EDT 2009
Rich,
I've done this recently, I've attached the code. Its mixed with some
application-specific stuff and is configured to show text distances on
each segment but it does show how to do something differently on move
vs click
Cheers
Paul
OpenLayers.Control.Measure.prototype.EVENT_TYPES = ['measure', 'measurepartial', 'measuredynamic'];
measureControl = new OpenLayers.Control.Measure(
OpenLayers.Handler.Path, {
textNodes: null,
showDistances: !Browser.Engine.trident,
persist: true,
geodesic: true,
partialDelay: 300,
callbacks: {
create: function() {
this.showDistances = !Browser.Engine.trident;
this.textNodes = [];
rulerLayer.layer.removeFeatures(
rulerLayer.layer.features);
modify: function(point, line) {
// introduce a delay for IE browsers so they will
// draw the first segment
if (!this.showDistances) {
return;
var len = line.geometry.components.length;
var from = line.geometry.components[len - 2];
var to = line.geometry.components[len - 1];
var ls = new OpenLayers.Geometry.LineString([
from,to]);
var dist = this.getBestLength(ls);
if (!dist[0]) {
return;
var total = this.getBestLength(line.geometry);
var label;
if (dist[1] == 'm') {
label = dist[0].toFixed(0)+dist[1];
} else {
label = dist[0].toFixed(2)+dist[1];
var textNode = this.textNodes[len-2] || null;
if (textNode && !textNode.layer) {
this.textNodes.pop();
textNode = null;
if (!textNode) {
var c = ls.getCentroid();
textNode = new OpenLayers.Feature.Vector(
new OpenLayers.Geometry.Point(c.x,c.y),
label: '',
fontColor: "#00F",
fontSize: "14px",
fontFamily: "Arial",
fontWeight: "bold",
labelAlign: "cm"
this.textNodes.push(textNode);
rulerLayer.layer.addFeatures([textNode]);
textNode.geometry.x = (from.x+to.x)/2;
textNode.geometry.y = (from.y+to.y)/2;
textNode.style.label = label;
textNode.layer.drawFeature(textNode);
this.events.triggerEvent('measuredynamic', {
measure: dist[0],
total: total[0],
units: dist[1],
order: 1,
geometry: ls
handlerOptions: {
layerOptions: {
styleMap: new OpenLayers.StyleMap({'default': {
strokeColor: "#00F",
strokeOpacity: 0.3,
strokeWidth: 5,
strokeLinecap: 'square',
fillColor: "#FFF",
fillOpacity: 0,
pointRadius: 0,
pointerEvents: "visiblePainted",
label : ""
var hasMeasure = false;
measureControl.events.on({
measurepartial: function(evt) {
measureControl.showDistances = true;
if (hasMeasure) {
$('RulerTotal').set('html','');
hasMeasure = false;
measuredynamic: function(evt) {
if (hasMeasure) {
hasMeasure = false;
var measure = evt.total;
var units = evt.units;
var label;
if (units == 'm') {
label = measure.toFixed(0)+units;
} else {
label = measure.toFixed(2)+units;
$('RulerTotal').set('html', label);
measure: function(evt) {
var measure = evt.measure;
var label;
if (units == 'm') {
} else {
hasMeasure = true;
var features = [];
measureControl.handler.layer.features.each(function(f){
features.push(f.clone());
rulerLayer.layer.addFeatures(features);
measureControl.cancel();
On 2009-09-18, at 9:39 AM, Richard Greenwood wrote:
> On Fri, Sep 18, 2009 at 1:47 AM, Andreas Hocevar
> <ahocevar at opengeo.org> wrote:
>> Hey-
>>> I'm trying to make sense of measure versus measurepartial event
>>> types
>>> in OL 2.8. Mouse moves and single clicks both report an event type
>>> of
>>> "measurepartial". Only a double click report a "measure" event
>>> type. I
>>> would like to distinguish between an mouse move (rubber band) and a
>>> single click (which creates a new vertex in the line string). The
>>> only
>>> way I have figured out so far to do this is to monitor the length of
>>> event.geometry.components but it seems like there should be a better
>>> way, which possibly I am missing.
>> The Measure control does not register a callback for the handler's
>> modify event, which means that you normally receive a measurepartial
>> event on a single click and a measure event on double click. If you
>> also
>> receive measurepartial on mouse move, then you have configured your
>> control with a callback on the handler's modify event,
> Andreas - Thanks for the reply. I did configure a callback for the
> modify event as you noted. Sorry not to have mentioned that in my
> original post. My problem is that I am unable to distinguish between a
> mouse move and a single click. I need to do different things in
> response to these two types of events.
> Thanks,
> Rich
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
