[OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
fsalas fsalas at geocuba.cu
Fri Sep 18 17:14:36 EDT 2009
Arnd,
Thanks very very much for your help, the map is show, as you said I forgot to insert a projection block.
My finaly objetive is obtain one maps change the sld_body params, but its don't affect the maps.
This is part of my code
 function init(){
   var options = {
   projection: new OpenLayers.Projection("EPSG:4267"),
   displayProjection: new OpenLayers.Projection("EPSG:4267"),
   units: 'degrees',
   maxResolution: 0.05115824837085553,
   maxExtent: new OpenLayers.Bounds(-86.09240990784447,19.463031059956343,-72.99589832490545,23.634939943479928),
   controls : []
   map = new OpenLayers.Map('map',options);
             // setup single tiled layer
     layer0 = new OpenLayers.Layer.WMS(
     "Cuba","http://urano/cgi-bin/mapserv.exe?map=d:/ms4w/apps/OpenLayers/data/educacion.map",
           {    layers: "Cuba",
                format: "image/png",
                 transparent: 'true'
             layer0.isBaseLayer=true;
            map.addLayers([layer0]);
            // setup controls and initial zooms
            map.addControl(new OpenLayers.Control.PanZoomBar());
            map.addControl(new OpenLayers.Control.Navigation());
            map.addControl(new OpenLayers.Control.Scale($('scale')));
            map.addControl(new OpenLayers.Control.MousePosition({element:$('location')}));
            map.addControl(new OpenLayers.Control.LayerSwitcher());
function Mostrar()
 map.layers[0].mergeNewParams({SLD_BODY:'<StyledLayerDescriptor version%3D"1.0.0"><UserLayer><Name>topp:cuba</Name><UserStyle><Name>UserSelection</Name><FeatureTypeStyle><Rule><Filter xmlns:gml%3D"http://www.opengis.net/gml"><PropertyIsEqualTo><PropertyName>codprov</PropertyName><Literal>pinar</Literal></PropertyIsEqualTo></Filter><PolygonSymbolizer><Fill><CssParameter name%3D"fill">%23FF0000</CssParameter></Fill></PolygonSymbolizer></Rule><Rule><LineSymbolizer><Stroke/></LineSymbolizer></Rule></FeatureTypeStyle></UserStyle></UserLayer></StyledLayerDescriptor>'});
Best Regards,
Salas
  ----- Original Message -----
  To: 'fsalas'
  Sent: Friday, September 18, 2009 1:50 PM
  Subject: AW: [OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
  Hi salas,
  as the message says, you have forgotten to insert a projection block in the mapfile on map level.
    PROJECTION
      'init=EPSG:4267'
    END
  Arnd
  Von: fsalas [mailto:fsalas at geocuba.cu]
  Gesendet: Freitag, 18. September 2009 19:28
  An: Arnd Wippermann
  Betreff: Re: [OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
  Arnd, the problem persist , I atach the imagen error and the map file and the html file.
  I don´t know how resolve this problem, can you chek this files?
  Regards , salas
  From: "Arnd Wippermann" <arnd.wippermann at web.de>
  To: "'fsalas'" <fsalas at geocuba.cu>
  Sent: Friday, September 18, 2009 10:28 AM
  Hi salas,
  Now have a look at your OpenLayers code. I suggest, that you have no options
  set for your map.
              var options = {
                  projection: new OpenLayers.Projection("EPSG:900913"),
                  displayProjection: new OpenLayers.Projection("EPSG:4326"),
                  units: "m",
                  numZoomLevels: 18,
                  maxResolution: 156543.0339,
                  maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
  20037508, 20037508.34),
                  controls      : []
              map = new OpenLayers.Map('map', options);
  It is an example for the google projection.
  Arnd
  -----Ursprüngliche Nachricht-----
  Gesendet: Freitag, 18. September 2009 18:14
  An: Arnd Wippermann
  Cc: users at openlayers.org
  Arnd,
  I don't Know why in WMS request ,the EPSG is different of 2085, Its
  EPSG:4326
  Sent: Friday, September 18, 2009 9:06 AM
  You have not added the projection block to the layer. Perhaps it is needed,
  i'm not sure. I declare always a projection for the map (as default output),
  and for the layers (the data have to be in a specific projection).
  If the problem remain, do the next:
  The message comes, when the WMS requests for an EPSG, that is not declared
  in the wms_srs tag. Have you in OpenLayers the projection for the map set to
  EPSG:2085. For the layer you need not declare the SRS, because OpenLayers
  add the EPSG from the map to the SRS parameter for the WMS layer.
  Use right click on your map to get the url for one tile of your WMS. Paste
  the url into the addressbar of your browser. The errormessage should be the
  same. But now you can inspect the WMS request. Look at the SRS. Is it
  &SRS=EPSG:2085?
  Arnd
  Gesendet: Freitag, 18. September 2009 16:31
  An: Arnd Wippermann
  Arn , I make your suggestion in my map file but the problem persist
  I atach my map file and the error image
  regards salas
  ___________________________________
  Dirección de Comunicaciones
  Grupo Empresarial GEOCUBA
  Este mensaje esta libre de virus.
  Revisado por Kaspersky Antivirus
  Definition count:  2596814
  Definition date:  9/18/2009
  SecurityPlus version: 3.0.5
  Definition count: 2596814 Definition date: 9/18/2009 SecurityPlus version: 3.0.5
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090918/c876b9d3/attachment.html
