[OpenLayers-Users] Performance Tuning in Internet Explorer
jim.meyer at concept-solutions.com jim.meyer at concept-solutions.com
Tue Sep 22 13:41:34 EDT 2009
Hi Till,
   We are using a lot of checkboxes on the client-side to generate a complex
query that determines which shapes to display.  This information is sent to
the server where a complex query runs and returns JSON to the client with
the shape data.  These shapes are rendered in a different color based upon
their time to activation.  I don't believe they are static enough to be able
to use WMS.
Thanks,
Jim
Jim Meyer
Java Programmer
ConceptSolutions, LLC
    We Make Business Intelligent
703.889.8434 [desk]
703.391.9041[fax]
www.Concept-Solutions.com
-----Original Message-----
Sent: Tuesday, September 22, 2009 1:00 PM
To: jim.meyer at concept-solutions.com
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Performance Tuning in Internet Explorer
Jim,
if it is just necessary to *SHOW* the shapes you probably might check to
serve them as WMS (try UMN  or GeoServer) or pure as UMN-CGI service ?
Doing that, your performance is an issue of the WMS server and not of
OpenLayers and there are many screws to work on like indexing,
scale-dependency and so on...and you are more browser independet,
because the only thing to show is an png or gif image.
Till
> Hi Christopher,
>    We are rendering active airspaces on our map.  We are required to
render
> this many shapes on the map.  Any other ideas?
> Thanks,
> Jim
> Jim Meyer
> Java Programmer
> 703.889.8434 [desk]
> 703.391.9041[fax]
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: Tuesday, September 22, 2009 11:37 AM
> On Tue, Sep 22, 2009 at 10:34:42AM -0400, jim.meyer at concept-solutions.com
> wrote:
>> Hi,
>>    We are rendering a vector layer that has 1000+ shapes.  Currently, it
> is
>> very slow in IE.  Any ideas as to where to start to improve performance?
> Render fewer shapes.
> Regards,
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
