[OpenLayers-Users] RE  measure with 2398
    Steve.Toutant at inspq.qc.ca
    Thu Sep 24 10:18:54 EDT 2009
Tim,
You might need to provide the proj4js definitions for your map projection
2398 to use geodesic: true
I already use it to transform coordinates, perhaps it is also required by
geodesic option.
If you want to try it, install the library and include theses scripts
<script src="../../../proj4js/lib/proj4js-compressed.js"></script>
<script src="../../../proj4js/lib/defs/EPSG2398.js"></script>
you'll probably need to create EPSG2398.js, have a look at other
definition files in the folder.
That works for me.
You can also have a look at this but I never used it.
http://dev.openlayers.org/docs/files/OpenLayers/Util-js.html#Util.distVincenty
Steve
Steve.Toutant at inspq.qc.ca@openlayers.org
Envoyé par : users-bounces at openlayers.org
24/09/2009 09:28 AM
A
Tim Balschmiter <tb.rostock at googlemail.com>
cc
Users at openlayers.org
Objet
Re: [OpenLayers-Users] RE  measure with 2398
I would try this
- Remove geodesic:true from the map option
- set the measure option like this
  var measureOptions = {
 persist :true,
 geodesic: true,
 handlerOptions : {
   style :"default"
hope this helps
steve
24/09/2009 09:06 AM
A
cc
Objet
Re: RE [OpenLayers-Users] measure with 2398
Thanks for these answer, but that idea does not work.
this is my map options:
  function createMap() {
            map = new OpenLayers.Map("map",{geodesic: true,projection:
"EPSG:2398",controls:[],scales:[442943842.5,221471921.25,110735960.625,55367980.3125,27683990.15625,13841995.078125,6920997.5390625,
3460498.76953125, 1730249.384765625,865124.6923828125, 432562.34619140625,
216281.17309570312, 108140.58654785156,
                    54070.29327392578, 10000.0, 5000.0,1000.0],maxExtent:
new OpenLayers.Bounds(4504884.5,5997999.5,4506172.5,5999757.5)});
            return map;
and that my new measure options:
 handlerOptions : {
   style :"default",
 persist :true,
 projection: "EPSG:2398",
 geodesic: true
2009/9/24 <Steve.Toutant at inspq.qc.ca>
Try to add geodesic: true as an option.
Is EPSG:2398, the projection defined in the option of the map object?
Steve
Tim Balschmiter <tb.rostock at googlemail.com>@openlayers.org
24/09/2009 02:17 AM
A
cc
Objet
Hello list, i am using the measure-option, but i get wrong  distance, if i
am using projection 2398.
What can i do to get the right values?!
thanks for helping me
tim
code:
 handlerOptions : {
   style :"default",
 persist :true,
var lineMeasure = new OpenLayers.Control.Measure(
OpenLayers.Handler.Path, measureOptions);
var polygonMeasure = new OpenLayers.Control.Measure(
OpenLayers.Handler.Polygon, measureOptions);
lineMeasure.events.on( {
"measure" :handleDistanceMeasurements,
"measurepartial" :handleDistanceMeasurements
polygonMeasure.events.on( {
"measure" :handleAreaMeasurements,
"measurepartial" :handleAreaMeasurements
function handleAreaMeasurements(event) {
var units = event.units;
var measure = event.measure;
var element = document.getElementById('messung');
var out = "";
out += "Fläche: " + measure.toFixed(3) + " " + units
+ "<sup>2</sup>";
element.innerHTML = out;
function handleDistanceMeasurements(event) {
var out = "";
out += "Distanz: " + measure.toFixed(3) + " " + units;
};_______________________________________________
Users mailing list
http://openlayers.org/mailman/listinfo/users
Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090924/c123b195/attachment.html
