[OpenLayers-Users] Reverse Geocoding
rmanor
ran.manor at gmail.com
Sun Sep 27 13:31:19 EDT 2009
I understand.
so I need to find a reverse geocoding service?
- Ran
On Sun, Sep 27, 2009 at 19:22, Stephen Woodbridge (via Nabble) <
ml-user+93143-1892360075 at n2.nabble.com<ml-user%2B93143-1892360075 at n2.nabble.com>
> wrote:
> rmanor wrote:
> > Is it possible to do reverse geocoding with OpenLayers (give
> > longitude/latitude and get street name/city name) ?
> > Thanks.
> Yes, but you probably need a server side component to do the actual
> reverse geocoding. For example here is an application that I build:
> http://imaptools.com/maps2/tiger.html
> if you single click on the map is will reverse geocode that location and
> put the results in a marker. If you click the marker it will open with
> the xml results in it.
> The single click does an Ajax request back to my server to do the
> reverse geocoding and then create a marker and puts the xml text as the
> contents of the marker. One could just as easily parse the xml and put
> is in a more human readable form in the marker.
> You can look the the page source to see how I did the client side of this.
> -Steve Woodbridge
> Users mailing list
> [hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3721218&i=0>
> http://openlayers.org/mailman/listinfo/users
> View message @
> http://n2.nabble.com/Reverse-Geocoding-tp3720968p3721218.html
> To unsubscribe from Reverse Geocoding, click here< (link removed) =>.
View this message in context: http://n2.nabble.com/Reverse-Geocoding-tp3720968p3721258.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090927/dad09018/attachment.html
