[OpenLayers-Users] Access to restricted URI denied" code:"1012"
when added WFS
Sasky
sassymaus at gmx.net
Tue Sep 29 04:14:43 EDT 2009
Hello,
When I write down this
http://localhost/cgi-bin/proxy.cgi?url=http://labs.metacarta.com/wms/vmap0
in Firefox, I get an empty white page.
I set up a Proxy like described on
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
but I still get the same errormessage.
I'm not using a Mapfish Server, so do I have to set this: mapfish.PROXY_HOST
= '/proxy/http-proxy.py';
Or does it has to be emtpy then: mapfish.PROXY_HOST = ' '; ?
Thanks a lot
Jorge Gustavo Rocha wrote:
> Hi Sasky,
> 1) To test OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
> You may have a syntax error in the allowedHost array (mission a ').
> But please do the following:
> Test the proxy directly in the browser, writing down the address of the
> proxy followed by the service url you want to use, like:
> view-source:http://localhost/cgi-bin/proxy.cgi?url=http://labs.metacarta.com/wms/vmap0
> If you write down this on the firefox, you should get:
> No query information to decode. QUERY_STRING is set, but empty.
> which is ok.
> 2) To test mapfish.PROXY_HOST = '/proxy/http-proxy.py';
> view-source:http://localhost/proxy/http-proxy.py/http,demo.mapfish.org/mapfishsample/trunk/polygons?maxfeatures=1
> {"type": "FeatureCollection", "features": [{"geometry": {"type":
> "Polygon", "coordinates": [[[15.493156433104, 51.733047485351001],
> [15.504142761229469, 51.715881347654815], [15.5175323486318,
> 51.718756675718822], [15.517189025877883, 51.742918014525017],
> [15.532981872557546, 51.723949432371782], [15.547744750975491,
> 51.729356765745891], [15.53847503662, 51.701805114745],
> [15.579330444335, 51.748840332029999], [15.530578613280625,
> 51.785232543944531], [15.495903015135999, 51.779396057127997],
> [15.495903015135999, 51.779396057127997], [15.493156433104,
> 51.733047485351001]]]}, "id": 12, "type": "Feature", "bbox":
> [15.493156433104, 51.701805114745, 15.579330444335, 51.785232543944531],
> "properties": {"name": "foo"}}]}
> Regards,
> jorge
> jorge gustavo rocha
> departamento de informática
> universidade do minho
> 4710-057 braga
> portugal
> N 41º33'44,5" W 8º23'40,5"
> tel +351 253604470 fax +351 253604471 cel +351 927210173
> Qui, 2009-09-24 às 04:33 -0700, Sasky escreveu:
>> I have a file called proxy.cgi and changed the hosts:
>> allowedHosts = ['localhost:5000', 'www.openlayers.org', 'openlayers.org',
>> 'labs.metacarta.com', 'world.freemap.in',
>> 'prototype.openmnnd.org', 'geo.openplans.org',
>> 'sigma.openplans.org', 'demo.opengeo.org',
>> 'www.openstreetmap.org', 'sample.avencia.com]
>> I also have a file mapfish_proxy.js containing the following code:
>> mapfish.SERVER_BASE_URL = '';
>> But it still does not work, FireBug still throws the same exeptions.
>> Do I have to change more than 'allowedHosts'?
>> (Sorry I'm a newbie)
>> Thanks a lot.
>> iweinzierl wrote:
>> > Hi Sasky,
>> > the WFS layer uses the XMLHttpRequest object to fetch its data. If you
>> try
>> > to
>> > request the data from a remote host, you get into the problem of the
>> Same
>> > Origin Policy [1], which denies loading data from remote hosts. To
>> avoid
>> > this, you will need to set up a proxy on the host your site is running
>> on
>> > see [2]). I hope this helps.
>> > [1] http://en.wikipedia.org/wiki/Same_origin_policy
>> > [2] http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
>> > Regards, Ingo
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/Access-to-restricted-URI-denied-code-1012-when-added-WFS-tp3704885p3734542.html
