[OpenLayers-Users] Text labels
Paul Spencer
pagameba at gmail.com
Tue Sep 29 08:57:35 EDT 2009
A simpler styleMap would be to take the Name directly from the
feature's attributes, but using a context to provide functions that
calculate per-feature styles is very powerful
var styleMap = new OpenLayers.StyleMap({
default: OpenLayers.Util.applyDefaults({
label: '${Name}', // this comes from feature.attributes.Name and
is case sensitive
strokeWidth:1,
strokeColor:"#CCCCCC",
fillColor: "green"
Cheers
Paul
On 2009-09-29, at 5:28 AM, Jan H. van der Ven wrote:
> Dear Nicholas,
> I use a StyleMap like so:
> "default":OpenLayers.Util.applyDefaults(
> fillColor: stateColors[layerIndex],
> fillOpacity: 0.4,
> strokeColor: stateColors[layerIndex],
> strokeWidth: 2,
> label : "${getName}", // see context below
> labelAlign: "cm",
> fontColor: "yellow",
> fontSize: "12px",
> fontFamily: "Verdana",
> fontWeight: "bold"
> ,OpenLayers.Feature.Vector.style["default"])
> ,"select":OpenLayers.Util.applyDefaults
> ({},OpenLayers.Feature.Vector.style["select"])
> // the labelFunction prevents the modify handles being labeled with
> "undefined"
> styleMap.styles["default"].context={getName: labelFunction};
> This StyleMap is then added as a parameter to the layer:
> var laag = new OpenLayers.Layer.GML(
> layerName,
> url,
> format:OpenLayers.Format.GeoJSON,
> visibility:false,
> styleMap:styleMap,
> isBaseLayer:false,
> And the labelFunction is used to show the label only at a certain zoom
> level:
> function labelFunction(feature){
> if (map.getZoom()>4){
> if (feature.attributes.name != undefined){
> return feature.attributes.name;
> }else{
> return '';
> }else{
> return '';
> The part about undefined has to do with edit handles.
> Kind regards,
> Jan
> Nicholas Efremov-Kendall wrote:
>> Hi all,
>> Sorry to bug you all with a pretty simple question. I have a shp file
>> converted to GML, with an attribute called "name." I'd like for this
>> to be places as a label by the polygon feature. I think, based on my
>> digging around on the lists that I need a function to first get the
>> feature.attributes.Name <http://feature.attributes.Name>, which would
>> then pass it to the label. Does anyone have a good example of this,
>> or
>> suggestions on implementation?
>> var cities = new OpenLayers.Layer.GML ("7th Century Cities",
>> "data/cities.gml",
>> style: {strokeWidth:1, strokeColor:"#CCCCCC", fillColor: "green"},
>> projection: new OpenLayers.Projection("EPSG:4326"),
>> format: OpenLayers.Format.GML,
>> label: "$name",
>> map.addLayer(cities);
>> Fulbright Student 2009-2010, Ukraine
>> nefremov at artsci.wustl.edu <mailto:nefremov at artsci.wustl.edu>
>> c/o Halyna Yerko
>> Balzaka 92a, Kv 27
>> 02232
>> Kyiv, Ukraine
>> (mob) +380963576524
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> No virus found in this incoming message.
>> Checked by AVG - www.avg.com
>> Version: 8.5.409 / Virus Database: 270.13.114/2401 - Release Date:
>> 09/28/09 17:53:00
> Users mailing list
