[OpenLayers-Users] Kml problems 2
Duncan Sayers duncansayers at threefivesouth.net
Wed Sep 30 07:33:08 EDT 2009
In lib/OpenLayers/Format/KML.js there is a comment in the method
parseFeature that says:
// only accept one geometry per feature - look for highest "order"
I wonder if this "one geometry per feature" bit is holding you up.
On 30/09/2009, at 7:51 PM, Vidal, Antoni wrote:
> Hello list,
> I have a kml file with two Placemark with a point and a polygon each
> one, but only the last is showed over the map.
> <?xml version="1.0" encoding="UTF-8"?><kml xmlns="http://earth.google.com/kml/2.0
>    <Document>
>     <name>ICC - Fulls 1:25.000</name>
>                 <Folder id="layer 0">
>                                <name>Tall 1:25.000</name>
>       <Placemark>
>          <name><![CDATA[67-23]]></name>
>          <MultiGeometry>
>             <Point>
>                <coordinates>1.2292789482351385,42.12505809906476</
> coordinates>
>             </Point>
>             <Polygon>
>                <outerBoundaryIs>
>                   <LinearRing>
>                      <coordinates decimal="." cs="," ts="
> ">1.31261326,42.16672373 1.14594315,42.16672487
> 1.14594468,42.08339244 1.31261474,42.08339135
> 1.31261326,42.16672373</coordinates>
>                   </LinearRing>
>                </outerBoundaryIs>
>             </Polygon>
>             </MultiGeometry>
>       </Placemark>
>       <Placemark>
>          <name><![CDATA[68-19]]></name>
>          <MultiGeometry>
>             <Point>
>                <coordinates>1.3959550858972396,42.458391895861894</
> coordinates>
>             </Point>
>             <Polygon>
>                <outerBoundaryIs>
>                   <LinearRing>
> ">1.47929122,42.50006088 1.31261965,42.5000564 1.31261912,42.4167232
> 1.47928988,42.41672697 1.47929122,42.50006088</coordinates>
>                   </LinearRing>
>                </outerBoundaryIs>
>             </Polygon>
>             </MultiGeometry>
>       </Placemark>
>                 </Folder>
>    </Document>
> </kml>
> Any idea why the first Placemark isn’t rendered over the map?
> Thank’s.
> Antoni Vidal
> Unitat d'Aplicacions SIG-WEB
> Institut Cartogràfic de Catalunya
> Parc de Montjuïc, E-08038 Barcelona
> Tel. (+34) 93 567 15 00 (ext. 3228)
> www.icc.cat
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
