[OpenLayers-Users] Combining Projection 26917 with Projection 4326
JamSquad
Jordan_R_Clark at hotmail.com
Thu Apr 1 09:58:40 EDT 2010
Hey!
I use proj4js and I'm having a problem with projections. Borders is the
base layer, and it is in projection 26917.
Proj4js.defs["EPSG:26917"] = "+proj=utm +zone=17 +ellps=GRS80 +datum=NAD83
+units=m +no_defs";
Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84 +datum=WGS84
+no_defs";
var proj26917 = new OpenLayers.Projection("EPSG:26917");
var proj4326 = new OpenLayers.Projection("EPSG:4326");
orthoBounds.transform(proj4326, proj26917);
options = {
controls: [new OpenLayers.Control.KeyboardDefaults()],
maxExtent: orthoBounds,
maxResolution: 425.12060546875,
projection: proj26917,
displayProjection: proj26917,
units: 'm',
numZoomLevels: 21
borders = new OpenLayers.Layer.WMS(
"Municipal Borders",
"http://10.10.30.88:8080/geoserver/wms",
{layers: 'InnisfilMunicipalBorder', transparent: 'true', tiled: 'true',
isBaseLayer: true},
{opacity: 0.5}
ortho = new OpenLayers.Layer.WMS(
"Ortho2008 - Tiled", "http://10.10.30.88:8080/geoserver/wms",
isBaseLayer: false,
layers: 'InnisfilGIS:Ortho2008',
styles: '',
format: format,
tiled: 'true',
tilesOrigin : map.maxExtent.left + ',' +
map.maxExtent.bottom
buffer: 0,
displayOutsideMaxExtent: true,
opacity: 0.3,
// projection: proj26917,
// srs: proj26917
These layers only show up alone, never together. Before, I merged Google
and 26917 and it worked, but this one is just giving me problems. If anyone
can help I'd appreciate it. Thanks
JamSquad
View this message in context: http://n2.nabble.com/Combining-Projection-26917-with-Projection-4326-tp4837221p4837221.html
