[OpenLayers-Users] Weird behavior when using stylemap in vector
layer and IE
MostlyBaldEagle
MostlyBaldEagle at shaw.ca
Thu Apr 1 17:43:37 EDT 2010
<p>The links below should demonstrate the part of the problem in IE7 and IE8
one example uses 2.8 the other dev (2.9+ ?)
</p>
http://n2.nabble.com/file/n4839836/test_2_8.htm test_2_8.htm
http://n2.nabble.com/file/n4839836/test_2_9.htm test_2_9.htm
View this message in context: http://n2.nabble.com/Weird-behavior-when-using-stylemap-in-vector-layer-and-IE-tp4838451p4839836.html
