[OpenLayers-Users] please help us test OpenLayers 2.9RC1
Tim Schaub
tschaub at opengeo.org
Sat Apr 3 01:01:47 EDT 2010
bartvde at osgis.nl wrote:
> Hi Arnd,
> thanks for your report. I've tracked that change down to:
> http://trac.openlayers.org/changeset/10044
> Tim, are you able to comment on Arnd's suggestion (see below)? TIA.
http://trac.openlayers.org/ticket/2561
Calling setCenter before adding layers has always failed. I considered
it equivalent behavior to require layers in the constructor if a center
was provided (and included a test to enforce this).
Arnd, while things might be working for you at 2.8, I'd consider it
somewhat risky to set map center (and zoom) in the options and then call
setCenter again with the same values after adding layers. There are a
number of checks that compare the current center/zoom to the values
passed to setCenter. If things haven't changed, I think it is
reasonable to assume that setCenter should do nothing.
Not sure what others think, but I can imagine that at some point we'd
forget this case and make it so setCenter had no effect if the passed
values were already set on the map.
Actually, it would probably be better to do whatever needs to be done in
setCenter without failing when there are no layers.
Anyway, the ticket is up for review.
Tim
> Best regards,
> Bart
>> Hi Bart,
>> I use the center parameter of the map options to store the center of my
>> map.
>> After adding my layers to the map I use map.setCenter with this
>> coordinate.
>> With the OpenLayers 2.9 RC1 library, this raise an error "maxExtent is
>> null", because if center is set in the options, this.setCenter is called
>> at
>> the end of the initialize-function. But then I have not added any layer to
>> the map.
>> It seems, that this will only work, if the layers parameter is also set in
>> the map options.
>> http://gis.ibbeck.de/OLClient/examples/testMapCenter_29_RC1.html
>> I would suggest, that the setCenter in the init function should only be
>> called, if this.options.layers != null.
>> // add any initial layers
>> if (options && options.layers) {
>> this.addLayers(options.layers);
>> // set center (and optionally zoom)
>> if (options && options.layers && options.center) {
>> // zoom can be undefined here
>> this.setCenter(options.center, options.zoom);
>> And I have noticed, that with exchange of the OpenLayers.js from 2.8 to
>> 2.9,
>> also the style.css have to be taken fom 2.9 with the css for the
>> LayerSwitcher control.
>> Otherwise it seems, that 2.9 works like 2.8. A great job from the
>> OpenLayers
>> developers.
>> Arnd
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
>> Auftrag von Bart van den Eijnden
>> Gesendet: Mittwoch, 31. März 2010 18:01
>> An: openlayers; users user
>> Betreff: [OpenLayers-Users] please help us test OpenLayers 2.9RC1
>> This is a reminder to everyone that OpenLayers 2.9 RC1 is out (since last
>> Friday), please help us test this release candidate by upgrading your
>> applications to 2.9RC1 and reporting any issues to us.
>> See also:
>> http://trac.openlayers.org/wiki/Release/2.9/Announce/RC1
>> Thanks in advance!
>> Best regards,
>> Bart
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
