[OpenLayers-Users] Vector layer: overlapping data
Daniel Degasperi
daniel.degasperi at r3-gis.com
Tue Apr 6 05:44:40 EDT 2010
Hi Tim,
I finally got the time to test the z-Index Feature and it works great!!
Thank you for updating the stylemap example.
Best regards,
Daniel
Am 25.03.2010 18:14, schrieb Tim Schaub:
> Tim Schaub wrote:
>> Daniel Degasperi wrote:
>>> Hi,
>>> I have a Vector Layer with Linestrings, which can also overlapp and I've
>>> applied a SelectFeature Control (with hover effect) to this Vector Layer.
>>> My question is, is it possible to bring the current selected feature on
>>> top of all features?
> I updated [1] the StyleMap example [2] to demonstrate how to use
> z-indexing with different render intents.
> In addition to using a graphicZIndex (will eventually be zIndex)
> property in your symbolizers, you need to enable z-indexing on the
> renderer. To do this, set rendererOptions on your layer as shown in the
> example.
> To see z-indexing with selection in action, refresh the example until
> you see overlapping points. When you hover over a point, the render
> intent changes to "select" and you should see the selected feature drawn
> over others.
> Tim
> [1] http://trac.openlayers.org/changeset/10144
> [2] http://openlayers.org/dev/examples/stylemap.html
>> See http://trac.openlayers.org/ticket/1066 for the change that made this
>> the expected behavior (not to bring selected features to the top).
>> We could provide an option to change this behavior.
>> Alternatively, you should be able to give your vector layer a style map
>> with different styles for the "default" and "select" rendering intents.
>> Using a graphicZIndex property in your symbolizers, you could have
>> selected features rendered above unselected features.
>> The graphicZIndex property is poorly named. It looks to me like it
>> should apply to any symbolizer - not just a symbolizer that uses an
>> external graphic. I'll confirm this and open a ticket about adding
>> support for a more appropriately named "zIndex" property on symbolizers.
>> Relevant examples:
>> Using graphicZIndex
>> http://openlayers.org/dev/examples/marker-shadow.html
>> Using a StyleMap with multiple render intents
>> Tim
>>> Best regards,
>>> Daniel
Daniel Degasperi
Software Developer
R3 GIS Srl
Via Johann Kravogl 2
I-39010 Merano - Sinigo (BZ)
Tel. +39 0473 494949
Fax. +39 0473 069902
Web http://www.r3-gis.com
