[OpenLayers-Users] Just another trasformation problem ;)
bartvde at osgis.nl
bartvde at osgis.nl
Wed Apr 7 06:17:09 EDT 2010
not sure if this is the cause of your problem since I don't know anything
about EPSG:2498, but can you try adding xy false to your Format.GML:
var isoline = new OpenLayers.Layer.Vector("isoline", {
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: "../aramus_data/vector/gml/isoipse_2498.gml",
projection: epsg2498,
format: new OpenLayers.Format.GML({xy: false})
Best regards,
Bart
> Hi all,
> I ought to display a map with osm layer as base and a gml file of a little
> part of Armenia.
> First step was convert my shapefile, with projection epsg:2498, in a gml
> format (ogr2ogr -f GML ...).
> Second step was set up my map.
> Within tag <head> of my html page, I' ve insert a link to these libraries:
> - OpenLayers-2.8/OpenLayers.js
> - http://www.openstreetmap.org/openlayers/OpenStreetMap.js
> - proj4js.js
> - proj4s/lib/defs/EPSG2498.js
> And this is a snippet of my map code [1].
> The problem is that my gml is in the north of Africa instead of Armenia.
> I've tried with qgis and the layer is correctly positioned, so I suppose
> that the problem is in the code, but I' m not able to detect the bug!!!
> thanks
> -beppe -
> [1] function init() {
> var epsg2498= new OpenLayers.Projection("EPSG:2498");
> var epsg900913= new OpenLayers.Projection("EPSG:900913");
> var epsg4326= new OpenLayers.Projection("EPSG:4326");
> var bounds = new OpenLayers.Bounds(44.532, 40.144, 45.038,
> 40.423).transform(epsg4326, epsg900913);
> map = new OpenLayers.Map ("map", {
> controls:[
> new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.LayerSwitcher({activeColor:"#729aa1"}),
> new
> OpenLayers.Control.MousePosition({div:document.getElementById("coord")}),
> new OpenLayers.Control.Attribution()],
> maxExtent: bounds,
> maxResolution: 156543.0399,
> numZoomLevels: 5,
> minZoomLevel: 3,
> maxZoomLevel: 8,
> units: 'm',
> projection: epsg900913,
> displayProjection: epsg2498
> var layerCycleMap = new OpenLayers.Layer.OSM.CycleMap("CycleMap");
> map.addLayer(layerCycleMap);
> var layerTilesAtHome = new
> OpenLayers.Layer.OSM.Osmarender("Osmarender");
> map.addLayer(layerTilesAtHome);
> var layerMapnik = new OpenLayers.Layer.OSM.Mapnik("Mapnik");
> map.addLayer(layerMapnik);
> format: new OpenLayers.Format.GML()
> isoline = OpenLayers.Projection.transform(isoline, epsg2498,
> map.projection);
> map.addLayer(isoline);
> -beppe-
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
