[OpenLayers-Users] ArcIMS thematic mapping example on Mapserver
sunny74
sb.ray at hotmail.com
Fri Apr 9 06:27:04 EDT 2010
Hi Bart van den,
I have found one way of doing the Thematic map i.e by hardcoding the style
in the map file corresponding to each feature.
That is the easiest way of doing it.
But that is not what I want to do.
I want to apply the styles to the features at run time and also be able to
manipulate the styles of the features at run time.
The SLD documents you sent only talks about manipulating the layers but not
the features within it.
Now I want to know the following:
1) How to access the map object and within that the layer object,class
objects using OL?
2) Apply styles to class objects within a layer?
Thanks for kind reply.
View this message in context: http://n2.nabble.com/ArcIMS-thematic-mapping-example-on-Mapserver-tp4871120p4876324.html
