[OpenLayers-Users] WMS GetFeatureInfo not returning results
Tobias Luetticke
Tobias.Luetticke at justice.govt.nz
Tue Apr 13 00:32:01 EDT 2010
Hi
I'm trying to get information back by executing a WMS GetFeatureInfo request, but without success. I am using the GeoServer Layer Preview function that in turn uses OpenLayers.
When I click on a feature on the map eg the following request is sent (copied from Firebug):
http://localhost:8080/geoserver/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=1929381.381188%2C5592303.911446%2C1941522.166813%2C5603614.760554&X=372&Y=170&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=test%3ATL_STANDARD_PARCEL&FEATURE_COUNT=50&Srs=EPSG%3A2193&Layers=test%3ATL_STANDARD_PARCEL&Styles=&WIDTH=512&HEIGHT=477&format=image%2Fpng
The GeoServer logs confirm that it receives the request and accesses the datastore. It also talks about writing to an OutputStream, but since I don't get any feature info back I can't judge whether that's all good or not. Checking Firebug for the response it confirms that HTML is streamed back from GeoServer, just the table that should contain the feature info is missing.
My configuration is
* GeoServer 2.0.1
* OpenLayers 2.8
* All running locally in my development sandbox
* Data coming from a shapefile data store
* GeoServer layer set to EPSG:2193 as declared SRS with SRS handling to "force declared".
I have confirmed with ArcGIS Explorer that the shape file contains the information I'm after. When I export data from GeoServer (again Layer preview) as GML the attributes are in there. There doesn't seem to be anything horribly wrong as the borwser/GeoServer roundtrip happens successfully. I guess somewhere I wired things wrongly together such that the request comes back empty.
Oddly enough, the GeoServer provided layer of US States (that uses shapefiles also) shows the same behaviour. However, on another GeoServer installation that shows the same configuration data comes back and a table showing the feature information is displayed.
What am I missing? Any ideas much appreciated.
Cheers
Tobias
This e-mail message and attachments do not necessarily reflect the views of
the New Zealand Ministry of Justice and may contain
information that is confidential and may be subject to legal privilege. If you
are not the intended recipient, you are hereby notified that you must not use,
disseminate, distribute or copy this e-mail message or its attachments. If you
received this message in error, please notify the Ministry of Justice
by telephone (call collect: 00-64-4-918-8800) or return the
original message to us by e-mail, and destroy any copies.
Thank you.
